I'll be honest, my wife bought the Blu-ray for Christmas and neither of us know much about them. We tried hooking it up and found out we needed the HDMI connection. I looked at the back of the TV before going to Radio Shack, and I didn't see an HDMI outlet, so I'm wondering if we can play any kind of Blu-ray player on this TV?
HDMI to AV Converter Composite 1080p HDMI to 3 RCA Audio Video AV CVBS Adapter HDMI 2 AV Converter Supports PAL/NTSC for HDTV DVD Amazon com HDMI to AV Converter Composite 1080p HDMI to 3 RCA Audio Video...
SOURCE: No connection/ no signal
Either the new BlueRay player is defective, the HDMI port on the player is defective, or the port on your set is defective.
Try connecting it with component RGB/AV cables, or S-Video/AV cables and see if everything works. If so, then you know that it is either the port on the BlueRay, or the port on the TV set.
To test the HDMI port on your TV, you will need another HDMI device to try.
Jerry G.
SOURCE: Need code for included blu-ray universal to work with an Olevia TV
if Samsung never included the brand Olevia on there remote, then its not going to work because it was never design to work with that brand. The only way to get around that is to get a learning remote or universal remote that has olevia pre program into the remote.. Olevia did come out with some learning remotes that is able to learn from other remotes.. the model its called Olevia RC-LRN ..
This company called Amergence Technology sells the RC-LRN remote made by Olevia contact them at this toll free number 866-965-3842
SOURCE: How to connect Panasonic BD60 Blu-ray disc player to 2 components
If there are red and white RCA jacks on the back of the BR player and on the receiver you should be able to get sound. The same as your VHS.
SOURCE: how to hook up insignia blu ray player to netflix
This model player (NS-BRDVD) is not Netflix capable. Netflix capable models are NS-BRDVD3, NS-WBRDVD, and home theater system NS-BRHTIB.
SOURCE: Sharp Blu-rAy player won't play Blu-ray discs but
Due to the nature of players often if the optical Pickup unit inside is dirty or failing Blu-rays will not play but DVD's will.
