I have a nexus 7 and a belkin wireless keypad - no mouse. my language is English UK. the @ and " keys are reverserse which is irritating and confusing, especially for email and passwords. I cant find a way to change this but I know it can be done with PCs and full keyboards.
SOURCE: Belkin Wireless Mouse
Today I tried pressing the reset button on the bottom of the mouse, and at the same time pressed the button on the top of the remote reciever. I'd pressed both in the past, but never at the same time. This seems to have fixed this problem. I hope it's a solution for others also.
SOURCE: wireless belkin keyboard
Hi. I have just worked out how to solve this as I had a similar problem. When you change the batteries of a Belkin Wireless Keyboard model F8E332ukBNDL you need to reconnect the keyboard to the wireless receiver that plugs into the USB port. To do this you press the 'Connect' button on the receiver and also press the green LED connect light at the top right of the keyboard - the one that flashes each time you press a key. I'm not sure in what combination you press these but I pressed them both and it worked.
SOURCE: belkin wireless keyboard receiver won't work with my laptop
Yes and no...
"Wireless enabled" means you do not need a separate adapter to connect to a wireless NETWORK or computer, not a peripheral device.
I assume the two connectors are PS/2- plugs - one pink, the other one green. What you need is a PS/2- -to-USB adapter that should have come with your keyboard. PS/2-in, USB-out, either with or without the cables (see picture)
SOURCE: Belkin Keyboard Drivers
hello
you can choose in this set http://www.touslesdrivers.com/
clik my drivers
...... Launch Detection
and install the plugin
..... search wath the drivers you need
SOURCE: Hi...my wireless keyboard stopped working. I
Yes, press the button underneath the keyboard and thenn the button under the mouse.
I read some other posts on this issue with keyboards and @ problems in general. I then set the "physical WIFI keyboard" to UK - it was set as default - and now the @ key works properly and the " key too! Thanks for help.
