Nokia C2-03 DUAL SIM DUALBAND PHONE NOT COMPATIBLE IN US/CA Logo
D
Dilawar ahmad bhat Posted on Mar 10, 2014
HOW I CAN RESTORE C2-03 MOBILE PHONE WHEN SWITCH OFF
RESTORE
haripriya
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 3 Answers
  • Posted on Apr 19, 2014
haripriya
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
Helped
795
Points
You cannot restore when your mobile is switched off. Switch ur mobile C2-03 go to settings, then scroll down to the last option restore factory settings.....they will ask you whether you have to restore simply settings or all data? It is on ur wish...select option, then enter the security code 12345 then click restore...ok. You will get your mobile restored!!
Micromax master resetting code all
1.NormalReset - Dial *#7780#
If you dial this code in Nokia handset, it will restore system setting without missing phone memory data (videos, photos, songs).
2. .Deep Reset - Dial *#7370#
When this code isdialed in Nokia handset, it will wholly clean internal phone memory. Entire phone settings and profiles will be deleted, but there is no effect on memory card data.
Remarks -
For Nokia Symbian 60 V1 supported mobile handset (7650, 3650, 3600, 3620, 3660, N-Gage)
you can dial *#7780#*#7370#
Latest S60 mobile handsets, you can dial Deep Reset through another way.
*.Switch off mobile handset first.
*.Press calling key (green), 3 and * keys or (Green calling button + 3 + *)at same time and grip them down.
*.You find a message about format mobile and then release these keys.
*. Password of Reset factory setting code will be either 1234 or 12345.
Nokia X3-02 mobile Restorefactory -
*.Go to Nokia menu lists, browse these options one by one-
*.Menu --settings-- Menu--- Restore Factory Setting
*.Insert phone code 12345and wait few moments to complete restore process.
Nokia 5230, 5800, 5233 and similar mobile handset Restore factory settings, how ?
*.Browse phone menu lists,
*.Then, go to
Menu - Settings - Phone -- Phone mgmt Factory settings
*.Insert security code -12345
*.Without data lost of internal memory, Nokia handset returns in original modes.
Hard reset of Latest Nokiahandset through another code -
*.Switch off mobile handset.
*.press and holdGreen (calling) +Red (End call button) + Camerakeys at the same time along with switch on power of mobile handset.
*.Then mobile asks to insert phone security lock code , so insert12345.
Samsung Restore factory code
*.*2767*3855#
*.*7465625*638*00000000*00000000#
*.#7465625*638*00000000#
or
*.Remove SIM card from mobile handset
*.Once off and on handset
*.Type *2767*2878# to perform internal memory reset
*.Insert SIM card again in mobile.
Samsung Androidsupport handset restore factory code -
Type*#*#7780#*#* - To Factory Restore.
Micromax Restore factory code for all version with Android -
You can use any following below code one by one to perform restore factory of Micromax mobile:
*.1122
*.0000
*.1234
=*symphony> 1122
=*nokia >5071 or 0000
=*micromax> 1234
=*tecno > 1234 or 0000
=*samsung> 1234
=*apale i phone >5869
BACK2HOME
Information from:
http://peperonity.com/sites/a--a.secret.mobile.codes/47096442
Terry
How to format Nokia 2700 Classic. my mobile is completed formated but still there is same problem.
1. Switch off your Nokia phone
2. Now Press following key sequence *#7370# or *#7780#
3. Enter Default lock code is 12345.
4. While holding these buttons, press the power button and switch on the phone.
5. Wait for message 'Format it
When i am opening nimbuzz on my nokia c2-06, my mobile is switching off immeadiately, tell me what i should do to use this application without going to service center
Hi first of all Restore your phone by selecting "Restore Setting Only" from the phone setting.And repeat the Nimbuzz.If the problem persist Remove the Nimbuzz and re-install.Otherwise contact nearest mobile repairing shop.Good luck
Mobile get switch off as entered into setting then tone setting then ringing tone so what will be the software problem and and will be the software code for it
RESTORE IT by typing *#7780# and after restore is complete then search again for ur problem if it still exists then switch off ur mobile and then again switch it on but before switching it on keep these keys pressed *456# or *,red key,green key hope this works
Nokia 2626 no signal
Hi, Switch off your phone and remove your sim card ,and after 10 minutes insert your sim card and restart your phone, if the problem still persist , restore it by selecting "Restore Setting Only" from >Setting>> Restore Factory Setting.Otherwise contact mobile repairing shop.Thanks for visiting fixya
Am not getting d picture wen i click.. it goes to standby mode.. i switched off and again i on.. it has no effect in it.. pls help me..
Restore your mobile with factory setting.. using restore factory settings in settings menu......
If problem does not solve than flash your mobile from the mobile phone shop........
Problem will be solved..........
May 18, 2011 • Nokia 7210
Hanging allkeys
If you restore the mobile can solve your hangink problem.
Before restore the mobile please take a full backup.
First Try it:
You may try default phone and security code to remove it
Default phones codes is 12345 or 00000 you can use it
Go setting>factorry setting >reset ....
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
If
Soft reset( factory setting)
On Sybmian phones:just type it it will start automatically,
*#7780# - Restore factory settings
*#7370# - Reformat your phone (back up your personal data with PC Suite or to the memory card first!)
If the problem same please Hard reset your mobile .
Back up your personal data with PC Suite or to the memory card first!
Switch-off your phone.
1. Press and hold three keys at a time;it is called "3 finger reset" which is depress these three keys simultaneously "*" "3" "green phone" and then power on phone whilst keeping those same three keys depressed until you see formatting.
If you don't understand, again follow the step.
You will use three finger for pres three keys ."green phone"+ "3" +star( *) and pres the power on switch.
All switch will be pressed at a time.
Soon an formatting text, will appear ,then stop pressing those switch,
Remember.
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory stetting.
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate and leave a short comment,that is your choice.
Hope this helps.
6helpful
2answers
Forgot my security code of nokia N72
if you want to restore the phone..
1. Switch of the mobile
2. hold the 3 keys - 3, * and the green button and switch on the mobile
The mobile will be restored to the factory settings
3answers
Blank screen after switching on the phone
the only way to restore your phone software is to contact the Nokia service Center it will be free if you have warranty an it will bw charged around $50-150
Apr 19, 2007 • Nokia 3230
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
