Just bought Nikon D60. No matter what mode I use for night shot - large grey shadow in bottom left corner of viewfinder, but doesn't show in shot. Using 18-55mm VR lens. Can't see most of show want to take.
maybe there is a smudge on the mirror, that is only noticeable in lowlight. take off the lens and look at the mirror. maybe there is a smudge on the mirror, that is only noticeable in lowlight. take off the lens and look at the mirror.
You can't post conmments that contain an email address.
Re: Just bought Nikon D60. No matter what mode I use
Looks like a viewfinder has an issue. If you have recently bought the thing just return it and get a new one. If not possible to replace , i recommend visiting Nikon authorised service center.
Could be something in the path of pentaprism.
since the camera has many adjustment, Read carefully the owner manual and go to the section troubleshooting and see the different adjust need for to fix it problem If you do no have owner m. go to www. retrevo.com and download God bless you
A few basic checks
Are you in full auto mode or some other shooting mode? Try different modes and see if any work.
Does the shutter speed seem slow - like you can hear it cl - ick. When photographers want a blurry effect, slowing down the shutter is often used. Change mode or set a faster shutter speed.
If none of these lead you anywhere, the imaging system that scans the imaging chip may be faulty. that's not a home repair.
Yes. The expore time is long when you picture at night. Use the flash or TRIPOD! ;) The other way is to change ISO. It's better if you change is to 800, or 1600 or 3200 but be careful, there will be a lot of noise then! ;)
Your're probably using a flash with TTL disabled. So 1/200 is the highest sync possible with that kind of flash. Did you try removing the flash off the body and setting faster shutter speeds?
D-SLR cameras are designed to be used with interchangeable lenses
and foreign matter may enter the camera when lenses are changed. Once
inside the camera, this foreign matter may adhere to the sensor, where
it may appear in photographs taken under certain conditions. To prevent foreign matter from entering the camera
do not change lenses in dusty environments
point the camera down when changing lenses.
To protect the camera when no lens is in place be sure to thread on
the body cap provided with the camera, being careful to first remove
all dust and other foreign matter that may be adhering to the body cap. Remove foreign matter from low-pass filter
Clean the low-pass filter covering the sensor as instructed in the camera manual or continue reading below.
The Nikon D300 and D60 has the ability to clean the sensor* using
the "Clean Image Sensor" feature. Please see page 371 in your D300
User's Manual, and page160 in your D60 User's Manual for more
information. *Clean Image Sensor may not remove all sensor
contamination and additional manual cleaning may be necessary. See page
374 in the D300 manual, and page 162 in the D60 manual for more
information.
Fix images with black spots
Photographs with dust or foreign matter on the low-pass
filter can be retouched using the 'Image Dust Off' function available
in Nikon Capture 4 or later (available separately) if the image was
taken in the NEF format, for more information visit the article on 'How does Image Dust off' work.
Yes. The SB-600 instructions don't mention the D60 because the SB-600 came out before the D60 existed. Bear in mind that the D60 does not have a commander mode so you can't use the SB-600 as a slave.
Basically, as far as the SB-600 instructions are concerned, just pretend that you have a D40.
