Hi. The Wi-Fi issue is related to the overheating problem.
All you need to know is here http://forums13.itrc.hp.com/service/forums/questionanswer.do?admit=109447627+1248179491352+28353475&threadId=1197437
And here http://forums11.itrc.hp.com/service/forums/questionanswer.do?threadId=1104931
Good luck
Regards Andrew
You hijacked my thread. :D
Who is 6ya anyway??
6ua , is fixya cash grab.
fees for service, you call them and pay and find the phones talking is useless too.
the overheat is simple
the fan is dead, or can not blow air past the radiator, out the exhaust vent.
99% of cases.
no need for phone talking,
get the PC serviced, tell them it overheats,
and to clean It out so it does not overheat.
90Centigrde also the processor (CPU) self shuts down at . by DESIGN, saving its own BACON.
yes I do.
and is here, with photos.
http://www.pcdied.com/overheated.html
the hyjacker left the building...like elvis.
all PCs overheat, when the air flow ends.
just like your car, does.
if you put cardboard over from of the radiator and drive, the engine cooling boils over.
on PC it just halts, (intel inside magic)
the cure is cleaning, it.
and not putting any laptop on top a blanket.
or it will overheat.
best is start your own post please
1: PC model and OS you run, tell.
2: tell what the PC does good bad and ugly
yes all 3 matter, computers are complex ok.
not like toaster at all.
if it only overheats say so.
as all ways it does is covered here and the cure.http://www.pcdied.com/overheated.html
in engineering overheating is said to be
a First order failure.
it is. (means fix that first)
run free app Hwinfo32.exe, portable from makers web site only.
+2 anonymous :)
Look closely at your statement. Works fine until the laptop overheats is an overheating problem, not a wifi problem. Make sure the air vents are clear from any dust or debris. Most laptops have a passive cooling system, so any blockabve of those vents can cause it to overheat. Also, when it overheats is it on your lap or on a hard surface? ironically, the worst thing you can do with a laptop is to use it whie it is on your lap. Your legs actually block the vents giving it no way to keep itself cool. The other thing to look at is the fan inside. Is it running constantly, intermittantly or not at all ever? The fan will only run if the CPU starts to get to a preprogrammed temperature. If it's running constantly, then it definitely needs to be looked at. likewise if it bnever comes on at all.
