Question about Black & Decker DF200 FryMate Fryer
Fryer heats up then starts beeping and shuts off
Why fryer heat up and than the gas shut off
If the pilot light goes off too, then the thermocouple is defective. Otherwise its the thermostat or heat overload protector trips due to excessive temperatures.
May 22, 2014 | Frymaster Dean H14 Deep Fryer
My Pitco fryer heats up and operate normally at 250 degrees when I set to 300 degrees, it heats up and when it reached 300 degrees, it shuts down bunner as well as the pilot light
CHECK THE SMALL SOLINOID THAT FEED THE PILOT IF THAT OPENES EVERYTIME THE FRYER STARTES THERES YOUR PROBLEM REPLACE IT AND ALL SHOULD BE WELL
Feb 09, 2014 | Pitco Frialator Kitchen Appliances -...
It keeps beeping and saying help
check the ignition system.controller will display help when burners do not respond during heat start-up or heat demands.also check if the unit receives sufficient fuel for ignition.
Mar 29, 2011 | Frymaster Dean FPH55-2 Deep Fryer
Pitco Fryer will not light up
Check the thermopile, it must be free of dirt or soot so that it can absorb enough heat from pilot flame and in turn can generate the right amount of voltage to energize pilot and burner coils.
Check also the gas pressure, it should be of standard as required on the unit's nameplate.
Apr 15, 2010 | Pitco Frialator SG14 Deep Fryer
I put it on any temp and it heats to 550 degrees
Replace the thermostat, P5047588. If the fryer is not shutting off, both main burner and pilot, when it overheats, also replace the high limit PP10084. The high limit usually shuts the fryer off at about 425-450F. Check your thermometer. A fryer should never get up to 550F.
Feb 24, 2010 | Pitco Frialator 35CS Deep Fryer
My Frymaster is beeping and coming up with a message HOT on the screen
Temp got to hot and shut down high limit. Also check for a broken wire to high limit
Sep 17, 2009 | Frymaster Dean H22 Deep Fryer
My fryer won't do a thing
there is a shut off swich and if you dont slide it into the deep fryer part correctly it wont turn on or do any thing the other is to make sure the breaker in the back of the unit is pushed in
Dec 01, 2008 | Euro-Pro F1066 Deep Fryer
Frymaster fryer mj45eusd
If this is an electric fryer you may have a shorted element that will continue to heat when ever the fryer is turned on,even when it is not calling for heat. If it has 3 phase power, the elements could be wired wrong
Sep 08, 2008 | Frymaster Dean Kitchen Appliances - Others
Black & Decker DF200 FryMate Fryer Logo
109 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Irene Tulloch
Gerry Harvey
Gerry Harvey
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
