The main oven is not working. neither the fan or the element come on. The upper oven/grill work perfectly
Hi not sure if you've had a reply but when my zanussi main oven stopped working i just changed the element (purchased from e bay).
open oven door and the back you will see 4 screws(basically 4 corners) remove these screws and you will see the element, pretty straight forward to remove, obviously fan wont work until you have heat (hopefully fan ok) you can give this a go, cheaper than buying a new oven. i have done this twice. hope this helps.
SOURCE: main oven wont work
It is the oven element that has failed
Remove panel at rear of oven compartment, there you will see the element, just undo any screws that you can see and pull the element towards you, carefully detach the wires, but don't loose them inside or you will have remove the oven to get the wires back on.
Fit new element and Bob's your uncle ,you've cracked it.
Plz leave feedback for this solution.
Thanks.
SOURCE: MAIN OVEN FAN STOPPED WORKING
Firstly switch off the stove isolator(switch)
1:I would suggest removing the back panel and checking the wires to the motor to see if any terminals have broken/fallen off(on the Zanussi ovens you should be able to see these easily).Also check that the armature can spin freely.
2:If OK, Switch isolator and stove back on and check for voltage (230v) to these terminals.
3:If No 1&2 solutions have not solved your problem please come back to me.
Hope I have resolved you question, but please leave positive feedback if so , as it still takes time to answer questions and it would just be nice to know if I have helped.
SOURCE: Zanussi ZDQ 595 fan oven not heating
Here is a free video to help you with your cooker fan motor problems
and how to fix them
For all your free videos on appliance repairs remember to
mark us down and leave feedback please
For all your parts visit our site http://www.apart4u.co.uk
