Steve Madden LED touchscreen watch
To change the date and time on your Steve Madden LED touchscreen watch, you will need to follow the instructions in the user manual that came with the watch. If you do not have the user manual, you may be able to find information on how to set the time and date online or by contacting Steve Madden customer support.
To set the time and date on most LED touchscreen watches, you will need to press and hold a button on the side of the watch for a few seconds until the time and date display appears. You can then use the buttons on the side of the watch to set the time and date. The specific buttons you will need to use and the sequence for setting the time and date may vary depending on the make and model of your watch.
As for the timer, you will also need to refer to the user manual for instructions on how to use it. The timer function may be accessed through the watch's main menu or by pressing a dedicated button on the side of the watch. Again, the specific steps for using the timer will depend on the make and model of your watch.
If you are unable to find the user manual or are unable to set the time and date or use the timer function, it is recommended to contact Steve Madden customer support for assistance. They will be able to provide you with specific instructions for your watch.
