Question about Magic Chef CYE2000 Electric Commercial Dryer
Magic chef dryer will do everything but spin, What should I do?
    President:
  • 3,085 Answers
You probably have a broken drum drive belt. Your local appliance parts store will have them.
It's an easy part to replace.
Posted on Jun 13, 2009
6ya staff
SOURCE:
How does the cylinder belt go on a magic chef, model #cye3005aye
Kinda tricky but you reach in and grab the idler making sure the belt aint twisted, Pull it far enough to loop the belt on the idler and let er go. Give it a few turns to make sure it ain't twisted. Made a phone vid with my bud Robert:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 16, 2012 | Magic Chef CYE3005AYW Electric Dryer
Magic Chef front load dryer is not spinning?? worked yesterday
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 04, 2011 | Magic Chef Dryers
I own a Magic Chef model YG225LV and the drum stopped spinning. Looks like I need to disconnect the vent and gas lines and open it in back to get to the belt for replacement. Can you confirm that?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Yes, on most dryers that is correct...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Sep 01, 2010 | Magic Chef Dryers
MAGIC CHEF WASHER WONT SPIN OUT
underneath the washer is a pully assembly kit . remove the belt ,the c clip and replace the pully kit about $ 20.00 cost for parts.
Feb 02, 2010 | Magic Chef CAV4000AWW Top Load Washer
How to get at the belt on my Magic Chef Dryer
YOU NEED TO POP THE TOP UP BY GETTING A FLAT SCREWDRIVER OR SOMETHING IN THE GAP UNDER THE LID.
ONCE YOU GOT THE TOP OFF THERE SOULD BE TWO SCREWS HOLDING THE FRONT ON.
Sep 21, 2009 | Magic Chef CYG2000AWW Gas Dryer
Dryer problem
I could be wrong, but I don't know of a dryer that DOESN'T use a belt to turn the drum. If the motor is turning on, and the drum is not spinning, more than likely your suspicions are correct and the belt is broken. You can find a replacement at searspartsdirect.com. Just type in the model number you have provided and look under the "Tumbler" heading for item number 5 (part #341241). The website also offers some helpful exploded view illustrations to assist in part location and installation.
Repairclinic.com carries the part at a cheaper price (item number 529597). Use the part number provided by the Sears website for your search criteria. Repairclinic also offers dryer belt installation diagrams. Just click on the "Repair Help" link at the top of the page and look under the "Special Features" section on the following page for "Dryer Belt Diagrams". Magic Chef uses diagram F. I hope you find this information helpful. Let me know if you have any questions.
Oct 26, 2008 | Magic Chef CYE4000AWW Electric Dryer
Magic chef dyer
dryers have a 'thermal fuse' that will cause the whole thing to turn off. it seems like yours has burned out. it may be caused by a restriction in airflow, so when you replace the thermal fuse make sure you clean the exhaust or the fuse may go out again.
Aug 08, 2008 | Magic Chef CYE4000AWW Electric Dryer
MAGIC CHEF DRYER CYE2000AYW
eather the element went out are the thrmal fuse 2nd time timer will not move if not heating
Mar 05, 2008 | Dryers
Dryer quit working
I have a Magic Chef Clothes dryer. Model #YE224LV. Was drying clothes, went back to ckeck and dryer wasn't running. Push botton and nothing. Check circuit breaker everything ok. What do I need to check and how. Just won't start.
Thank you!!!
Nov 11, 2007 | Magic Chef CYE4000AWW Electric Dryer
Magic Chef CYE2000 Electric Commercial Dryer Logo
Top Magic Chef Dryers Experts
Gene Pitts
jimorris77
Nathan Van Boven
Nathan Van Boven
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
