I am using EPSON cartridges rather than other brands.
SOURCE: printer won't print color
when you change the ink cartridges you are NOT changing the print head. The print head is in the carrier. If the print head has become clogged or worn then usually it needs to be replaced. Unfortunately it us probably cheaper to buy a new printer.
SOURCE: Epson Stylus DX8400 empty ink cartridges but actually new
Sometimes there is a coating on the chips (even original epson ones!) - Old wives tales say dont touch the chips with your fingers - but take the carts out one by one and wipe your finger over the chips (1 finger for one chip - dont reuse the same finger on a different chip)
Reinstall them and that worked for me on a dx4500 with original epson carts in
SOURCE: I have no way of changing the ink cartridge in my printer.
Hi, the information you need is here:
http://support.epson-europe.com/onlineguides/en/sc46/index.htm
Just click on the replacing ink cartridges on the left hand side, follow the instructions and pictures there.
SOURCE: (Epson Stylus C60)red light blinking, says contact
keenepadgl, "Contact service engineer" for a C60 used to be all you could do. Now you can go to SSC Service Utility and download it. But the red light blinking (if that is all that is happening) simply means you have a ink cartridge that is low but not empty. If the red light stays on, then it means a ink cartridge is empty. By downloading SSC Service Utility you can solve about any problem you have with a C60. That's what the "Service Engineers" use. Check out the protection counter reset in SSC, that is the main reason people had to send their C60s to have serviced., and what service would do is press the reset button in SSC program. NOTE: I would go to inkmizer and get some cleaning fluid instead of nail varnish remover.
SOURCE: How to clean my Epson RX595 Photo All In One
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
