Question about Technics SL-DZ1200 CD Player
Cd stuck in cd player not ejecking - Technics SL-DZ1200 CD Player
My 3 disc change not working properly. cd are d2 and d3 and will not ejeck
Loosen 4 screws on bottom. You may want to take the two front ones out. They are phillips head. Drop the botom portion of the changer down about an inch or so. You will see all the disc that are stuck. Take a pair of micro plyers and simply grab the edge of the disc and gently pull and it will come out very easily Be sure and grab the very edge of the disk so as not to damage it. It took me all of 5 minutes to remove the disc in a 3 disc changer. What caused it to become stuck in first place is another question. You shoud have a green light beside each slot that has a disc in it.
Sep 24, 2016 | Bose Wave music system Multi-CD Changer...
Why is radio stuck?
radio stuck in phone mode Cars & Trucks Questions ...
www.fixya.com > Forum > Tags > radio stuck in phone mode
Cars & Trucks radio stuck in phone mode questions and answers. Ask your radio stuck in phone mode car and truck question. Get free help, advice & support for ...
CD Player Stuck on Eject Mode & my Truck isn't ... - Car Talk
community.cartalk.com/.../cd-player-stuck-on-eject-mode-my-truck-isnt-...
Apr 28, 2009 - CD Player Stuck on Eject Mode & my Truck isn't Even On !! ... It won't accept a CD, but the stereo still works; however, the digital screen shows ...
Dec 29, 2015 | Cars & Trucks
Cd stuck in Dennon cd player so draw will not close nor can I use the player
Try undoing the screws around the side and back. Top should then slide off and you should be able to remove disc. Make sure it's NOT PLUGGED IN!!
Nov 29, 2013 | Denon Audio Players & Recorders
How to remove stuck CD in CD player
Is there something inside the Player preventing it from not "Ejecting"?
If there was a Mechanical Failure inside the CD Player then you are going to have to remove the Player, and mechanically disassemble the Player to (1) Remove the CD, (2) Repair the Player for future use...
Apr 07, 2013 | 2006 Cadillac CTS
My 2002 ford escape in dash cd player gives me an error when i try to ejeck my cd's
You can take the unit to the dealer order an exchange unit. When you send in your old unit they will return the CDs. If it has a CD error they are not going to come out unless the unit is dismantled.
Jun 01, 2010 | 2002 Ford Escape
Cd's are stuck in cd player and will not eject,
i have a 2005 kia Amanti. i believe a cd is stuck and the cd palyer will not rptate or eject. does anybody have a solution?
Dec 11, 2009 | 2004 Kia Amanti
DVD player in 05 Nissan Quest will play a DVD then quit
Did it come back on later? Did you try a different DVD ? Cars are a harsh inviroment as cars get parked in the sun and left out in the cold and tend to change interior temps very quickly and condensation can build up rust and fogg up things. Did you try running a CD cleaner disk? Can you hear the disk turning as the DVD or cleaner disk is in there ? Do the function buttons light up? If its plum dead no sounds no ejeck it could have blown a fuse. If it seems to be going but not making a picture or auitio sound and the cleaner disk or other disk is no help the bulb may have gone out. In the dark with a clear disk CD or DVD doesnt matter in it you should see some light coming out where the disk goes. If not the bulb may have gone out Call the geek squad at curcuit city and tell them what you find and they'll tell you the troble your in cheapest.
Aug 13, 2009 | TMI Products VizuaLogic...
Cd is stuck
takc cd player out remove cover and press on edge of cd to egect it manualy recommend replacing cd player
Dec 09, 2008 | JVC KD-S5050 CD Player
Cd door player is stuck
Break it open. Then buy a new cd player.
Apr 20, 2008 | Curtis RCD843 CD Player
Technics SL-DZ1200 CD Player Logo
80 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
