Watch new battery installed still wont work
First you have to check if the battery is on full power, as sometimes even brand new batteries are underpowered. Good battery should have 1.54 - 1.57 Volts of charge.
If battery is ok and watch still not working - get the battery out and clean (scrape) all battery related contacts with steel needle untill they are shiny. Use the dust blower to get rid of cmall dirt particles.
Replace the battery. Now the watch should work.
If the watch doesn't work after cleaning contacts, then this is mechanical fault and you will need watchmakers help.
Do not forget to rate, please.
