Pioneer PL-990 Turntable Logo
A
Anonymous Posted on Mar 08, 2014
Replaced belt and Truntable is goinng too slow
Belt slows down when I step on it no matter what speed. Need help to determine why treadmill slows down.
Is the belt correctly tensioned. Do you feel that the belt is slipping. Does the motor noise change and slow down, or does the motor sound the same? If it slows, then the motor is failing, or you have exceeded it's weight capacity. If the motor remains at the same speed, then the belt is slipping with you as the resistance on it.
I have a Makita belt sander,just replaced belt tensioner system including springs and roller but belt drive roller still keeps stopping on relatively light load even though the motor is running
very good trade tool
how quickly is it getting hot
slowing motor could be the cause
motor bushes and bearings can be replaced
did the motor drive belt under the cover get replaced
2answers
Ihear the motor and the power is on. But the truntable is not turning. Could the belt have slipped off?
99,9% the belt is either slipped off or cut.
Pull up the rubber mat, pull up the platter and find the belt. If the belt is removed from the platter, replace it with the glossy side outward. Pull the platter back at the original position. Turn until one of the 2 big openings come over the motor pulley. With your finger place the belt from the platter at the motor pulley. Pull the rubber mat back. You are ready. Here is a schematic for all the above:
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Technics SL-B205 turntable runs too slow
I have a Techniques SL-23--just bought two brand new belts. One runs too slow and the other too fast.
How do I fix it?
1992 egale talon turns over slow the starter is
How was the starting BEFORE all this work was done. Why was the timing belt replaced.
No signal in home
With sprint you can get an Airave device that will be like your own personal cell tower covering up to 5,000sqft in your home, however no carrier will garuntee service indoors... I would stick with sprint we have the largest 3g and 4g networks and can get service indoors with the Airave device.
1helpful
Optimus lab 1100 truntable will not operate.
this is a belt driven platter. the belt is old and fell off. http://www.archive.org/details/Turntable_Belt_Installation
this link shows how to replace a belt, once you see where the belt goes thread a piece of string through the mechanism where the belt should go and measure it and contact them with the length. or measure total length of the old belt if still in one piece. figure about $14 for most belts.
1helpful
Too slow?
above is a generic video that applies to almost all belt driven turntables including yours that will show how to install the belt and a few other things.
this can be caused be a new belt being too wide, you may need a narrower belt.
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
