Sewing Machines Logo
Posted on Jun 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore Sewing machine model 385.1884180, feed dog quit pulling
The feed dog moves up and down but does not pull the fabric through. I pressed a flat tip screwdriver against a rounded mechanism near the outside edge of the throat plate and it worked until I locked stitches. Then it stopped pulling. Now it won't move any more.
Thank you
Jean Quick
Dunn, NC
Anonymous
Level 2:
  • Expert 208 Answers
  • Posted on Jun 19, 2009
Anonymous
Expert
Level 2:
Answers
208
Questions
0
Helped
111940
Points
701
A common malady with Kenmore sewing machines. The feed system needs lubrication and perhaps some solvent cleaning to loosen sticky pivot points. If you are adventurous, you could take off the bottom and oil all the moving parts. Or take it to a service person.
Ellen Den Dulk
Level 1:
  • Contributor 25 Answers
  • Posted on Jun 23, 2009
Ellen Den Dulk
Contributor
Level 1:
Answers
25
Questions
Helped
10247
Points
69
Sometimes there is a lot of lint build-up in the feed dog, it may want to move, but it can't because of the dust. Remove dust before you oil!
3answers
I have an old Kenmore Convertible 1785 machine. It is working fine except it won't pull fabric thru. Any suggestions on what could be wrong?
Are the feed dogs in the up position? Is your fabric very slippery or silky? If it is you need to use a tear away for the feed dogs to grab on to I order to move the fabric forward.
2answers
Singer model 518....the material won't feed through.It wants to sew but won't feed cloth through. Thks
Be sure you have the stitch length set high enough that the fabric will actually move instead of sewing mostly in one spot.
One other thing to check is the presser foot applying enough pressure to the fabric so that the feed dogs can grab the fabric? On the top left side of the machine, there is probably either a dial or a push-type button. That would most likely be the pressure adjustment. The tighter that is set, the harder the pressure the presser foot will apply and the more the feed dogs will grab the fabric.
Check that the feed dogs are in the "up" position so they will pull the fabric through the machine. Are the feed dogs actually moving forward, raising above the needle plate, pulling toward the back of the machine, and then dropping below the needleplate before moving forward again? If not, then the problem could be with the feed dogs.
Your machine appears to be a mechanical model. If so, it could be the machine needs a good over-all cleaning and oiling--a couple drops of fresh, good quality sewing machine oil every place that metal rubs on metal (no plastic parts, belts...). Feed dogs are frequently affected when the sewing machine does not receive regular maintenance.
Feed dog not moving fabric forward
it would be a good idea to have the feed dogs checked to see why
they are not moving the fabric
2answers
I just got an old Sears Kenmore Sewing machine model 385.17781. Everything is working fine except the reverse stitch. When the reverse button is pressed, the fabric doesn't move or sometimes movin
it sounds like the feed dogs & the reverse button need to be
checked at a repair shop,
to see why they are not responding to each other.
1helpful
2answers
Cloth does not move . It sews when I pull the cloth myself, but it does not automatically moves the cloth by itself
Make sure your feed dogs are up. Feed dogs are moving metal parts in the needle plate that make the fabric move forward under the presser foot. Open up the shuttle box underneath the needle plate. There is a lever to the right of the the shuttle. Press the lever down and to the left to raise the feed dogs.
2helpful
2answers
Feed dogs are not pulling the material back
White sewing machine model 510, feed dog problem; fabric is not moving; I must firmly pull fabric through.
The feed dog is moving; fabric is not.
The fabric is not feeding properly; the fabric goes back and forth. However, the fabric does not continue to move away from me.
The feed dog is positioned up and is not smooth, it feels rough when I touch it with my fingers.
Because I had not used this sewing machine for a couple of years, before sewing, I cleaned the inside with the wire brush that came with the machine.
In an attempt to trouble shoot the problem, I applied varying pressure foot levels and stitch lengths.
Does anyone have any suggestions as to what may be the problem?
2helpful
2answers
My kenmore 385 won't feed fabric
Check to see what pattern is selected. Be sure it isn't the buttonhole.Select straight stitch.Move the stitch length setting to 4.Turn the handwheel and see if the feed dogs move forward. Press the reverse lever and see if they move backwards. Select straight stretch stitch and turn the wheel to see if the feed dogs move forward and backward.Check the presser foot release on top of the machine and make sure there is pressure on the foot.
Sometimes the reverse assembly on this machine stops working because it has the wrong type of grease on it and it turns into a hard gummy mess that won't let it work.
sewman7
4helpful
3answers
Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link mechanism.in addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
Fabric wil not feed thru machine
adjust your feed dog hight. manual shows u how
5helpful
2answers
Dropping Feed dogs on kenmore model 19233
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
Top Kenmore Sewing Machines Experts
ZJ Limited
ZJ Limited
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
