Question about 7752V Replacement Transmitter Supercode Remote for 5901 Responder LC3
How do i set the alarm to automatically lock - 7752V Replacement Transmitter Supercode Remote for 5901 Responder LC3
Peugeot 508 RXH: I cannot lock the car with the remote. The doors lock, but unlock again. The car detects open doors correctly. I can lock the doors with the dashboard button.
If you have 2 remotes does it do the same thing with both of them?
I/We have a Honda FRV and if you set the alarm from outside the car ....which locks the doors ...and the doors are opened from the inside, (yes I have set the alarm whilst still in the car,) this unlocks the doors as the drivers door has the master central locking switch on it. If I close the door withing a few seconds the alarm reactivates itself and the doors relock automatically
Presumably when your doors unlock the alarm is disarmed? Maybe your issue is linked to the receiver in the security system?
There is a difference, presumably, between you locking the doors from the dash as opposed to doing it from the remote control, the security system is not armed in the former, only the doors are locked +
GOOD LUCK
Jul 19, 2015 | Peugeot Cars & Trucks
Mercury Mountaineer car alarm sounds for no reason
Try using the doorkey after the door has been closed as if you did not have power locks. But most of the time, its automatic with the antitheft.
A shorting battery can activate the antitheft system. Have the battery tested.
Feb 04, 2014 | Mercury Mountaineer Cars & Trucks
How do I set factory alarm on 2000 ford explorer Eddie bower
Lock the Doors.... The Alarm automatically sets.
Apr 06, 2013 | Cars & Trucks
2004 honda accord ex doors lock and alarm sets automatically
does the dome light come on when the drivers door is opened, if not the pin switch is bad
Jan 20, 2013 | Honda Accord Cars & Trucks
I have 98 Camry Le and the door locks lock automatically shortly after the doors are unlocked and the alarm will set also. What could be the problem? Alarm Control Box?
if you use the keyless entry to unlock the vehicle & don't open a door within 30 secs.the vehicle will automatically lock & the alarm will reset,if you unlock it with the key this shouldn't happen.....cheers.
Sep 01, 2011 | 1998 Toyota Camry
How do i manually release the rear door on a ssab 9-3 2003 as the door module has failed
Trunk Lock After Closing
Desc.: What happens to the trunk lock when closing it.
Settings:
Yes: Automatically lock Boot on closing
No: Boot can be reopened using micro switch button located on the trunk/boot
* Trunk Lock After Drive Off
Desc.: Should the trunk be locked at drive off or after 30 sec.?
Settings:
Yes: Trunk/Boot will automatically lock when vehicle increases speed
No: Trunk/Boot will remain closed, however will be in the unlocked
condition if No was selected in the previous option.
* Door & Trunk Unlock at Key Out
Desc.: When the is removed from the center console should door/trunk
be unlocked?
Settings:
Yes: All Doors & Trunk/Boot will Unlock when the Key is removed from
the Ignition Switch If Driver frequently locked all Doors when
driving
this feature would be beneficial.
No: Doors and Boot will remain in the same condition as they were
prior
to Key removal
* TSL Locking Logic (Theft Security Locking/Deadlock)
Settings:
TSL at first Press: Default Setting. All Doors will lock in Deadlock
Mode
TSL at Second Press: All Doors will lock in Deadlock mode at the second
press of the Remote.
* Lock /Unlock Acknowledge
Settings:
None : No acknowledge will be visible
Indicators: Indicators will blink as acknowledge
* Follow Me Home Function
Settings:
Tail Light: When selected Tail Lights will be illuminated
Back Up Light: When Selected Reverse Light will be activated
Tech 2 Body Exterior Lighting & Horn
* High Beam Follow me home Active Time
Desc.: Follow Me Home Active Time can be adjusted between 0- 10 minutes
Settings:
This Feature can be turned on or Off .Yes / No can be selected.
Low Beam Automatic / Low Beam also in Position 0 (light switch)
Yes / No
- Daytime Driving Lights can be activated
* Parking Lights
Settings:
Act as Lead Me To the Car Light.
* Park Light On Reminder
Settings:
On / Off
If Ignition is turned Off and the parking lights are active, Driver will
be warned if set to on.
* Show Trailer Light Outage
Desc.: REC will detect blown trailer light and display on SID
Settings:
Yes or No
* Trailer Light / Fog Light off
Settings:
Yes: Fog Light Rear will be disabled When Trailer is connected Yes
No
* Horn Lock Unlock Acknowledge
Settings:
On: Horn will honk when car is locked
Off: Horn will not honk if car is locked
Tech 2 Body Locking
* Panic Alarm Activation (Vehicles fitted with /Alarm only)
- Panic Button / Locking Switch
Central Locking Switch Driver /Passenger
Settings:
- Panic Button on Remote and locking switch inside vehicle will
activate alarm
- Panic Button will activate Alarm only
- Locking Switch inside vehicle (driver /passenger will activate
alarm only
- No Panic Alarm function required.
* Unlock Logic
Settings:
All at first press : All Doors will open & Fuel Lid will unlock if the
Driver or Passenger Door Switch is activated
Driver Door & Fuel Lid at first press : Only the drivers Door will unlock
& Fuel Lid will unlock when door
switch is activated
* Remote unlocking One Press
Settings:
All at first press: All Doors will open & Fuel Lid will unlock if the
Remote is pressed
Driver door & Fuel Lid at first press: Only the drivers Door will unlock &
Fuel Lid will unlock when the Remote
is pressed
Dec 17, 2010 | 2003 Saab 9-3
1998 Jeep Grand Cherokee alarm will set on its own when closing the door even if I do not set the alarm with the remote. Is this normal?
Are you using the power door locks after the car is turned off?
This too (I find) will engage the alarm, automatically.
in my opinion, the jeep factory supplied alarm system is not "normal"
i am still trying to figure out how to permanently disengage
Feb 18, 2010 | 1998 Jeep Grand Cherokee
How set a alarm lock for my brookstone sensor clock?
You have to press and hold the up arrow while in Alarm mode to enable the alarm, and press and hold the down arrow while in Alarm mode to disable the alarm. Setting the alarm automatically enables the alarm.
Oct 02, 2009 | Brookstone Audio Players & Recorders
The alarm is automatically set with me not even controlling it.
Go to a toyota dealer they can reprogram your settings on your car so it won't do that.
Dec 16, 2008 | 2002 Toyota Camry
7752V Replacement Transmitter Supercode Remote for 5901 Responder LC3 Logo
62 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Larry Tezekjian
Larry Tezekjian
david griffin
david griffin
Level 1 Expert
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
