Pioneer DEH-P6600 CD Player Logo
A
Anonymous Posted on Mar 08, 2014
Dehp6600 wont power up - Pioneer DEH-P6600 CD Player
My rci2980wx wont power
the diode is located near power cables and trace from power switch, the diode is quit big and something like IN4001 to 6 Re: Jeff
My automatic windows wont roll down
Click the link below to troubleshoot the problem:--
Power windows not operating?http://whoisbyme.blogspot.in/2012/05/car-window.html
Thanks.
I dont know how to use the cd player
Heres the manual - http://caraudio.manualsonline.com/manuals/mfg/pioneer/dehp6600.html
My cda-9813 wont power on,how to take of faceplate?
sure it will the face eject button should be either on the upper or lower left corner of the face.
5helpful
2answers
1helpful
Power windows and power locks wont work
Check your fuses first. Then check for power at the switches, and power from the switches to the respective solenoid and motor. Most likely it's fuses. Also check where the wiring runs through the door into the car for bare spots in the wiring that might have blown the fuses.
2answers
Car wont start and there is no power to it at all. The security light is on?
do you know if you have an anti-thieft device in your car. sounds like it may be armed and connected to your battery.
Purchased a jeep with pioneer dehp6600 receiver.
Remove the speakers and trace the signal pairs (wires) to their origin, maybe they are still factory harnessed where you can access a connection point behind the head unit. Here are the factory color codes .
Hope this helps
Aduz
JEEP up_arrow.gif P o w e r Memory (+12v Constant) Pink Ignition (+12v Switched) Violet/White Ground (-) Black Illumination Orange Dimmer Blue/White Power Antenna
S p e a k e r s Right Front (+) White Right Front (-) Black Left Front (+) Green Left Front (-) Black/Yellow Right Rear (+) White/Black Right Rear (-) Brown Left Rear (+) Green/White Left Rear (-) Brown/White
Top Pioneer Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
