This problem relates to the Main Motor Drive on the printer.
The L4 error details that the Motor Drive has been Overloaded.
Try disconnecting the power and blowing it out with air-cleaner
Sharp AR-450
H5
01
Papersensordefective in the fusing unit
02
Fusing unit temperature error
C1
00
MC unit malfunction
C2
00
TC unit malfunction
E7
00
Image Processing Unit error
01
Memory back-up battery dead
02
Laser unit problem
03
HDD defective
10
black level calibration error
11
white level calibration error
13
CCD calibration error
90
F1
00
Lost communication with the Sorter
01
Sorter registration problem
02
Paper transport motor overloaded in sorter
04
Bin position error in sorter
05
06
Shift sort motor overloaded
08
Stapler position error
08
Stapler overloaded
11
Sorter problems
14
Second shift tray jammed
15
Sorter drive problems
50
Sorter not installed properly
80
No powerin sorter
F2
00
ID pattern reading error
02
Toner add mechanism malfunction
31
32
39
Drum thermistor error
F3
12
Paper does not lift in the tray
22
F9
00
Printer board problems
01
02
03
Network card error
04
Firmware error
05
Not enough memory
10
90
H2
00
01
H3
00
Overheated fusing unit
01
H4
00
The fusing unit doesn't heat up
01
H5
01
02
L1
00
Scanner position error
L3
00
L4
01
Main motor drive overloaded
L6
10
Polygon mirror motor not up to speed
L8
01
Zero cross signal error
02
U2
00
EPROM error
11
EPROM error
U4
02
Duplex not working properly
03
Duplex problems
U5
00
Communication with the ADF is lost
01
Registration sensor problem in ADF
02
Exit sensor error in ADF
03
Timing sensor problems in ADF
11
Paper feed drive overloaded in ADF
U6
01
Paper lift problem in 1'st optional tray
02
Paper lift problem in 2'nd optional tray
08
Paper feed unit without power
10
PFU paper transport motor overloaded
22
50
Paper feed unit not installed properly
51
LCT not installed properly
U7
00
Main board malfunction
U9
00
Op panel problem
90
Op panel problem
EE
EU
Low toner density in the developer
EE
EL
High toner density in the developer
FA
01
PC
Key counter not installed
L4 means that there is an overload in the drive system. Check the developer unit if its running smoothly or the drum. Make sure the exit unit is not jamming. This can be done by openning the cover on the right side and you will see a small motor. Clean its sensor.
Sharp AR-122
Код ошибки
Подкод
Описание
C1
00
MC unit malfunction
C2
00
TC unit malfunction
E7
00
01
02
Laser unit problem
03
HDD defective
10
11
13
90
F1
00
01
02
04
05
06
08
08
Stapler overloaded
11
Sorter problems
14
15
50
80
No powerin sorter
F2
00
02
31
32
39
F3
12
22
F9
00
01
02
03
Network card error
04
Firmware error
05
Not enough memory
10
90
H2
00
01
H3
00
01
H4
00
01
H5
01
02
L1
00
L3
00
L4
01
L6
10
L8
01
02
U2
00
EPROM error
11
EPROM error
U4
02
03
Duplex problems
U5
00
01
02
03
11
U6
01
02
08
10
22
50
51
U7
00
U9
00
Op panel problem
90
Op panel problem
EE
EU
EE
EL
FA
01
PC
Sharp AR-650
Код ошибки
Подкод
Описание
C1
00
MC unit malfunction
C2
00
TC unit malfunction
E7
00
01
02
Laser unit problem
03
HDD defective
10
11
13
90
F1
00
01
02
04
05
06
08
08
Stapler overloaded
11
Sorter problems
14
15
50
80
No powerin sorter
F2
00
02
31
32
39
F3
12
22
F9
00
01
02
03
Network card error
04
Firmware error
05
Not enough memory
10
90
H2
00
01
H3
00
01
H4
00
01
H5
01
02
L1
00
L3
00
L4
01
L6
10
L8
01
02
U2
00
EPROM error
11
EPROM error
U4
02
03
Duplex problems
U5
00
01
02
03
11
U6
01
02
08
10
22
50
51
U7
00
U9
00
Op panel problem
90
Op panel problem
EE
EU
EE
EL
FA
01
PC
CC
Original not detected
E1
00
10
11
ASIC error
12
13
ROM error
14
NVRAM error
15
Page memory fault
16
SIMM not present or installed incorectly
17
Page rotation error in RAM
80
Electronic sort board error
81
82
84
88
E7
03
Lens position error
04
White level calibration error
05
Black level calibration error
12
F1
06
F5
02
Exposure lamp blown
F6
00
Fax board problems
10
80
81
82
84
88
F9
00
10
80
81
82
84
88
H2
00
H3
00
H4
00
L1
00
L3
00
L4
01
10
Separation motor overloaded
L6
10
L8
01
U2
04
EPROM error
11
Main counter error
12
EPROM error
U3
29
Mirror position error
U9
00
Op panel problem
81
82
84
88
U95
Firmware error
E7
03
04
Exposure lamp blown
05
12
14
15
Exposure lamp blown
L1
00
L3
00
L4
01
L6
10
H2
00
H3
00
H4
00
U2
01
Counter error
04
EPROM error
CH blinking
Dev unit is not properly installed
