Kenmore Elite refrigerator model 106.74209402. Fridge compartment is freezing. Sears repair guy concluded the control board was bad (without running diagnostics). I replace it myself, but the problem persisted. I was then told by a repair guru on another on-line board that the problem was the thermistor in the refrigerator control box. When I replaced it, however, there was no change.
Is the problem with the damper? If so, is there some way to confirm the problem before shelling out more bucks? And is this what the Sears parts lists calls the "baffle" (part 2300528 or 2315515)?
It is the part # 2315515. It is a motororized contraption that opens and closes the baffle to let the freezer air into the refrigerator. It is one part. Mine shut closed. I removed the whole thing in hopes I can do without it. It will be a trickey proposition getting the freezer temp adjusted just right enough to keep the fridge just right enough. The repair man said they are seeing alot of these right about now. They don't make em like they used to.
