My acer 5610 f8 short cut key does not turn up / down the volume or mute
SOURCE: Acer Aspire 5610 Volume and DVD problem
I have had this problem before with the exact same model.. I had been on the phone with technicians and they guided me through a series of troubleshooters with which none of them worked.. Unfortunatly the only way I managed to get it running again was to restore my laptop to factory
SOURCE: FN + F11 "turned on" at boot up
This feature is turned on and off in the system BIOS.
During startup, hit either the DEL or the F2 key to enter the setup.
Read through the items found there until you find the keyboard options.
good luck.
tony
SOURCE: I have an acer aspire 5601AWLMi notebook and recently installed..
WELL I THINK U HAVE A PROBLEM WITH COMPATIBLILTY SO u need to uninstall the lateset driver then u need to clcik right click of ur lastest driver chen check the compatibilty to windows xp sp2 then apply it then try to install it again
SOURCE: fn f5 not working and volume bars not showing when
Acer management software not loaded. Doa system restore to a day before the problem started. If still no good, alt+F10 at boot time to restore it to factory condition. Back up important files first, as this will wipe the c: drive....
let me know if this works or not.
SOURCE: My touchpad no longer works and some keys on my
Hi there uninstall the key board driver from the laptop, then restart it again and install the driver from acer driver disk. Bbut before these please try the step below mentioned.
1. Restart the PC and repeatedly hit F8 until you have a menu in front of you.
2. You will find few option there. Just select these mention option " Last know good Configuration ...." use by your up/down arrow on your keyboard.
3. Press enter there.
4. your will see the system asking you for which OS you want to use. If you have only one OS then just press ENTER there or select the OS and Enter.
After these if you face the same problem then format the OS & install it again.Thanks & waiting for your feedback.
