Where would I find the wiring diagram for a Samsung Security Camera SOC-a101? It is a 6 prong plug and I need to connect a PS2 connector to it.
I have a Samsung soc-a101 digital color security camera, wires corroded off male plug to camera what is the wiring sequence to the plug? wires are: red 12 volt looking at pin's front side not back of plug, from plastic tab pointed up red is on right top terminal, audio is top left terminal which I assume is white wire, then I have a clear plastic covered wire and the bare stranded wire. what terminals go to these wires I assume the bare wire goes to the metal ring of the plug as it had a wire soldered to it just don't know which! this leaves the bottom pins on the left and right set of two and the two bottom pins! Can you help? remember I am looking at the front not back where the wires are soldered. Thanks.
