To connect your Emerson TV to a remote control, you can follow these steps:
Make sure the batteries are properly inserted in the remote control.
Turn on the TV.
Locate the remote control sensor on the TV.
Point the remote control directly at the sensor and press any button to see if the remote is working.
If the remote is not working, try changing the batteries or resetting the remote control.
If you are still having trouble connecting the remote to your Emerson TV, you may need to consult the TV's manual or contact the manufacturer for further assistance.
Check if the batteries both are giving at least 1.5volts each. Clean the terminals of the remote control to secure proper contact with the batteries. Check if the negative terminal of the remote have enough pressure to keep the batteries firmly inside the remote control. Point the remote to the sensor of your air conditioner and press the power button. Changing direction of the remote control pointing to the air conditioner while pressing power button. If still air conditioner does not work clean the sensor eye to remove dust and switch again the unit.
First try changing the batteries. Next make sure when you press function on the remote control the red light on the remote displays under tv
Next try a remote reset:
You
have to unplug the television after turning it off. Take the batteries
out of the remote control. Point the remote toward the remote sensor
(bottom right hand corner of the television set). Press the power
button on the remote control and hold it down for 30 full seconds. Next
press and release every button on the remote control. Next plug the tv
back in and power it on from the power button on the television itself.
Replace the batteries. Adjust the volume using the remote control. If
that works the problem is solved. If it doesn't work you may need a software update, a new remote control, or repair to the sensor on your television.
To see if your remote control is working look at it through the viewscreen of a digital camera.
The digital camera must be turned on and ready to take a picture. Next
press a channel button on the remote control. Do you see a bluish white
light? If so the remote control is ok.
You have to unplug the television after turning it off. Take the batteries out of the remote control. Point the remote toward the remote sensor (bottom right hand corner of the television set). Press the power button on the remote control and hold it down for 30 full seconds. Next press and release every button on the remote control. Next plug the tv back in and power it on from the power button on the television itself. Replace the batteries. Adjust the volume using the remote control. If that works the problem is solved. If it doesn't work you may need a software update, a new remote control, or repair to the sensor on your television.
To see if your remote control is working look at it through the viewscreen of a digital camera. The digital camera must be turned on and ready to take a picture. Next press a channel button on the remote control. Do you see a bluish white light? If so the remote control is ok.
The two batteries are the ones in the remote? Make sure they are installed correctly. The camera will need to have a decently charged battery as well. Put the camera in P mode, pop up the flash and allow to charge. Make sure you pre-focus the camera on one subject or near the subject. The remote is supposed to focus the camera, but the camera may not fire if it cannot focus or if it needs the flash.
And most importantly make sure you are setting the camera drive button to remote so the camera knows to work off the remote. This button is in the upper right hand side on top and you will press the button and turn the control dial until the remote symbol appears. The remote should be pointed at the camera and will work best if you point it at the remote sensor on the front right side. make sure the strap or nothing else is obscuring the sensor.
If non of this helps, you may have a bad remote. Contact your retailer for a replacement
There are two optaions for you to find one, one of the simpler ones would be to find a video game store and ask if they have the booklet in stock and they should be able to give you one, or you can try e-bay, im sure there is something on there. I hope I have helped you in anyway.
The IR sensor in the tv is probably weak, you could make a mountain out of a mole hill and get it replaced (using your friends receipt ^_^) but there's nothing to be done about the sensor.
