Question about Konica Minolta Dynax 5D / Maxxum 5D Digital Camera
Memory card will not go in all the way and the door won't shut.
  • Steven Hamilton
    Steven Hamilton Mar 07, 2014
    The door closes fine with no card. I install the card and the slot won't close.
  • Steven Hamilton
    Yes card is in the right way, I don't see anything in the slot, and I blew it out anyway to no avail. Thanks though.
  • 706 Answers
Was it working before?
turn the memory card anyway and have a try - before check inside the memory card compartment with a flashlight if you can see the contacts at the bottom and insert the card corresponding to them.
Or try another card to exclude yours is not damaged or wrong type somehow....
Konica Minolta MAXXUM 5D Instruction Manual Inserting And Changing Memory...
Memory card will not go in all the way and the doo - memory-card-will-not-go-in-all-way-door-4qf1labpgcqiqwpsaxwo3k5u-3-0.jpg
Posted on Mar 02, 2015
    New Friend:
  • 21 Answers
Ok dumb question i'll ask here , is the card in the right way? and two if you look down into the slot do you see anything clogged at the bottom? if so a can of compressed air will help.
Posted on Mar 07, 2014
Testimonial: "Yes card is in the right way, I don't see anything in the slot, and I blew it out anyway to no avail. Thanks though."
Anonymous
SOURCE:
Camera shows write protect when open
When what is open? Always keep the battery / memory card door closed. If it is not closed correct, the camera won't work as expected. To protect the file system, when someone should pul out the memory card, while the camera is accessing the memory, it will or shut down completely, or at least protect the memory card against writing to it.
Before opening the battery / memory card cover, always make sure the camera is completely shut off. That means no light is allowed to burn or flicker. The memory card can also be write protected (SD cards) when the lock switch is down like in the picture on the 32GB card.
Before you can make any picture the switch on the card should be up like on the 64GB card on the picture. 3635bcf4-65df-478c-a04d-92e341d15860.jpg
Jan 29, 2014 | Cameras
Fujifilm xp30 that won't turn on.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Dec 16, 2011 | FUJIFILM FinePix XP30 Digital Camera
Canon powershot SD1300 IS won't turn on, even with fully charged battery
Oct 11, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Camera won't register that there is a memory card, always saving pics to internal memory
Did you use a high capacity memory card with an old camera? For example, did you use a SDHC card in a somewhat old camera?
Some cameras accept only SD card. Although SDHC card has the same shape, it won't be reconized by the camera.
Sep 23, 2011 | Cameras
My Canon Powershot SX120is camera was dropped on a high school gym floor. Since then it hasn't turned on. I think the battery connections on the little battery door are damaged, since you can tell...
Jun 25, 2011 | Canon PowerShot SX120 IS Digital Camera
I cannot connect my LG GU280f mobile phone to my computer to download photos
Maybe you won't have to... If the phone has a memory card, and you find a card reader, what it takes is to move everything from the phone memory to the card, shut down the phone, move the card to the USB card reader and copy everything from the card, in your computer. Nothing easier...
Apr 26, 2011 | Computers & Internet
The camera FujiSD8000 i have won't turn on. Used fresh batteries, has not gotten wet, but i was recently involved in a car accident and the camera was in the car with me when it happend. The camera looks...
Check the memory card or battery door for the tab that activates the cut out switch. It ,or the switch, may have sustained damage. I'm not 100% on this model but if it's like the S5700/ S5800 models then the memory card door has a tab for the cut out switch to prevent card removal whist powered up.
Apr 08, 2010 | Fuji FinePix S8000fd Digital Camera
Battery/memory card compartment wont close
Don't force it. It could be that your memory card is in backwards. This is a common cause for your battery door to not shut.
Hope this helps!
May 20, 2008 | Canon PowerShot A540 Digital Camera
Unable to shut door on battery and memory card cover
some memmery cards have to click in. press in click, press in click out. or memmory card needs to be turned around.
Feb 01, 2008 | Olympus Stylus 790SW Digital Camera
Broken door
Tape it shut is the only solution here No Spares no Repairs.
Jul 06, 2007 | Pix S-470S Digital Camera
Konica Minolta Dynax 5D / Maxxum 5D Digital Camera Logo
157 people viewed this question
Top Konica Minolta Cameras Experts
Ekse
 Larry
Larry
Pierre Laplante
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
