I put my GT6101 card in the port of my i3 processor without changing any of the display drivers and now none of the display is working, the monitor says "no signal" although the cpu is working. i cant access the computer unless i have a solution to the display
SOURCE: Monitor Shutdown problem
wow...lucky me...my problem solved....i search in many forum then i went to this place... (-----http://vip.asus.com/forum/view.aspx?id=20051025214627223&board_id=9&model=A9550+Series&page=1&SLanguage=en-us-------) it says that...
"Please enter windows device manager---system device, you should can find a VIA CPU to AGP controller (orVIA AGP2.0/3.0 controller),
Please update this controller driver, choose manually installation, don't search, show the compatible devices, then choose PCI standard PCI-TO-PCI bridge controller to update it, after this, reboot system and check if system run fine in games and video playback."
btw..i use Catalyst 7.8 (modified driver) download from (---http://www.techpowerup.com/softmod/downloads.php-----) bcoz i'm trying to overclocking it now...(-----http://forums.techpowerup.com/showthread.php?t=2716-------)...it works for me and i think maybe worth try for u...goodluck...
SOURCE: Is my Motherboard compatible?
Try to find out what the AGP voltage is on the motherboard.
Some graphics cards use 1.5 volts and some use 3.
If it's a 1.5 volt AGP slot and you plug a 3 volt graphics card in, it either wont work or you could permanantly damage both card and motherboard.
SOURCE: I need a Vista driver for Appian Graphics Rushmore Graphics Card
Look at your motherboard spec's and see what you have for a video card slot, then see what chipset
is running your board, if the chipset is ati then get an Ati card,if nvidia,then nvidia card.
I have never even heard of these card MFG, and don't see there support sites.
My opinion would be to go to a place online like Newegg.com and find a card for your board, a good cheap card will run about 30-40.00 dollars. The graphics will be a lot better on your pc.
If the cards came with the pc,you can try and go to the site of the pc maker and see if there is a vista driver, if not, you either have to reinstall xp or buy a new card. Hope it works out.
SOURCE: Nvidia Geforce 8400 GS (PCI)- easy installation is not so easy.
What sys prog are you running, rem not all progs are compatible. ie Vista? Pain the u no were!!
Linpus™ Linux® - Intel Core i3-350M (3MB Cache, 2.26GHz) - 2GB DDR3 RAM - 320GB SATA HDD - ATI Mobility Radeon HD 5470 with up to 3579MB of HyperMemory - Screen Size 14" HD 1366 x 768 resolution - Battery 6-cell Lithium Ion (Li-Ion) 4400mAh - Up to 6hours battery life
AS4745G-352G32Mnks
LX.PSM0C.037
Compare
Intel® Core™ i3 Processor
