I have a canon ir 6255 with error e00032-0001 after pressing copy. how can i resolve?
Hi javan,
Go To Below official Canon Printer Page For Your problem,
Canon imageRUNNER ADVANCE C5051 C5045 C5035 C5030 Manual List of Error... Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For Canon Printer Support
SOURCE: Canon imageRUNNER 2020 alternates between displaying Error Code E019 and saying "Waste Toner Full".
hi you have a waste toner error code, the waste toner is apart of the drum unit in these machines so you will need to order a new drum unit for it.
easiest way to fix the problem.
Canon Tech
SOURCE: Canon Ir 550 E020 error
When the scanner motor is started up, the BD input signal does not arrive within a specific period of time.
When
the scanner motor is started up, the motor rotation is too fast, and
fails to reach a specific revolution within 20 sec at time of
deceleration.
While the scanner motor is rotating at a specific
speed, the BD input signal cycle is not within a specific range (±2%)
for an equivalent of 10 mm (print distance).
While the scanner motor is rotating at a specific speed, the BD input signal cycle is not as indicated (±2%).
During
the WMUPR period after the power switch has been turned on or the front
cover/left cover has been opened/closed, the drum unit is absent.
Possible cause:
The wiring is faulty (short circuit, open circuit). The laser scanner
unit is faulty. The DC controller PCB is faulty. The drum unit is not
installed.
SOURCE: error e -070 in canon ir -3100 color copier
Its an error with the senor for the transferring belt. Try going into the additional functions-adjustments/ cleaning-gradation adjust- full adjustment. And follow the prompts on the screen. If this doesn't work and you feel comfortable trying you can clean the sensor. Remove the front covers, waste bottle and the drum. The sensor is located inside the chassy where the drum was at, in the middle (front to rear) on the left Do not use a vacuum on the sensor it can be damaged easily. After cleaning and reassmbling retry the gradation adjustment.
SOURCE: canon IR 2020 showing system Error E007 printer
my canon ir2020 is displaying system error E007
