It looks like it ought to be in a TV sales store. "Series 4, clear image panel, 600 hz, homi x3, mega dynamic contrast," in color and with logos, stay on screen for about 15 annoying seconds every five or so minutes or when volume is changed.
Here a video to help you turn off the retail display
http://www.youtube.com/watch?v=tEaxnPe13fQ
SOURCE: Right third image filled vertical lines when hot
Ive Had the same issue with my TV - and its really dissapointing to see it so well documented - obviously this is a design fault- its the last Philips TV im buying :(
SOURCE: Remote volume control for Sharp Aquos 42inch LCD not working
User 'rapolley' is absolutely right. One can cycle through the functions to access different options, ie. 'TV', 'Audio', 'DVD', etc. I stumbled upon this solution when I thought my 'Menu' button wasn't working. All I had to do is cycle through the 'Functions' and choose 'Menu' once I get to 'TV'. Thanks!
SOURCE: Best Picture Quality
Check this link out. I think it should give you all the info you need for optimal picture settings.
http://help.cnet.com/samsung_LN_T4061/9602-12576_39-0.html?messageID=2510125&tag=tip-2510125&kw=samsung+LN-T4061
SOURCE: My Phillips Plasma tv MENU pops up unasked and obscures screen.
there is a soft ware upgrade for that problem on there web site you can down load it to a thumb drive and upgrade your set
SOURCE: Sony Bravia No signal plus flickering image and
You know how to reset the tv to its factory setting, I think you are a technician. Second thing you can do is software update. Go to http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL42V4100&LOC=3#div_pos_30 . If it doesn’t work. Replace the Main board (UB board). Part # A-1547-086-A Cost approx $320.
Knowledge obtain from: Repair experience on same symptom.
Parts reference: Andrews electronics, 800 289 0300.
Your Cost: $640.79
