Windows cant log onto Belkin although Mobil phone will.
Sir,
Check your IP Address, Maybe its conflict with other device.
My advice to turn it automatically.
Or
Installing your Belkin router is still possible even without using its Setup CD. You can set up your router manually through the web-based setup page of the router.
Perform the steps below to set up your Belkin router through the web-based setup page.
NOTE: images may vary depending on the router model or computer you are using.
Power cycling the modem and router
Step 1:
Unplug the modem and router from the power source.
Step 2:
Connect the modem to the WAN or Internet port of the router.
Step 3:
Power ON your modem first, then your router by plugging them back to the power source.
Manually setting up your router
Step 1:
Connect the computer to one (1) of the Ethernet ports of the router.
Step 2:
Launch a web browser and enter "192.168.2.1" in the address bar.
Step 3:
my laptop wont log on to belkin - f43cf160-b3ef-4848-ae4a-ae3797a563b4.pnguploads/images/f43cf160-b3ef-4848-ae4a-ae3797a563b4.png" alt="f43cf160-b3ef-4848-ae4a-ae3797a563b4.png" class="h_mi" />
Step 4:
my laptop wont log on to belkin - 40e8d69f-22a6-4f6b-8eaa-2446bf156833.pngick Submit.
NOTE: If you don't know your Connection Type, contact your Internet Service Provider (ISP). To know how to set up your router according your ISP, refer to the links below:
Cable Internet Service
PPPoE / DSL
Static IP Account
Step 7:
Enter the details provided by your ISP and climy laptop wont log on to belkin - 116f45be-cc94-4208-82b8-1afa55cb7ea5.pngle to connect to the Internet. To verify, Internet Status on the upper right corner should read Connected.
You can also launch a web browser and go to your favorite website or try visiting the Belkin Site for more information and support on your devices.
as mention On official Belkin website vedio for Belking Online Support:
Setting up the Belkin router using an iOS device Video
Belkin
Or
In case you still need assistance then follow us for Belkin Tech Support on:Belkin Support
SOURCE: Can't access Belkin setup page 192.168.2.1 anymore.
There should be a small reset pin hole in the back of the device. Hold down the reset button for 15 seconds and it should reset the router to factory defaults
SOURCE: New Belkin router wont connect to internet.
your user name and password have been entered incorrectly, they are case sensitive and must be exact. Make sure your ADSL settings are set at 0/38 (you'll see where)
SOURCE: Belkin G Router cant hook up 2nd computer HELP
Get the same friend back out LOL :-)
First of all, look at the IP address the first computer has. That's done by pressing the Window symbol and "R". It opens up a box and you type CMD on the line and press OK. It opens up a new window and you type the command IPCONFIG and press enter. It will spit out a bunch of numbers, but the only 2 that matter is the first line telling you what address the PC has and the 3rd line telling you what the address of the Gateway is. Generally the Gateway is in the form of 192.168.2.1
That's the Belkin default but it may be something different. Now, the real question is what happens when you try to connect to the network from the new computer. Does it show your wireless network and is it secure? If it is, you're going to have to find the password. When you try to connect to the secure network, it will ask for a WEP or WPA key.
Go to the working computer, open Internet Explorer, and on the address bar type http://192.168.2.1 or whatever gateway address you got above. It will open up a new box with LOGIN in the upper right corner. If your "friend" didn't set a password, you'll get right in. If he did, remember the first line.
Outside of that, finding the security key should be easy enough to follow if you open this tutorial http://en-us-support.belkin.com/app/answers/detail/a_id/33/p/386
A WEP key is 10 or 26 hexidecimal characters (0-9, A-F) not case sensitive. A WPA key can be anything from 8-63 characters and it is case sensitive so MyKey is different from mykey or any other variation.
Your last resort is to reset the router, especially if it's a DSL. You will have to do a lot of extra programming and it usually requires the original paperwork for addresses, login, and password to the inernet to set up.
Carl
1st and most simple question is, your computer connected to the same network? Do you get any messages when trying to login into the router or just page cannot be displayed?
