I can't see my iPod Touch in "my computer", do I have to use iTunes? it is really annoying I would rather just do copy and paste.
Does anyone had this problem before?
Rich
One way to show your ipod touch in my computer is next: connect to internet through safari, save a random image from any web site to your ipod touch by holding your finger on the preferred image until a save image option appears,save the image. now connect your ipod and woila!
Andres L
There's a program called TouchCopy http://www.wideanglesoftware.com/touchcopy/ that you can use to access your iPod Touch as a drive.
If you have a mac, then the iPod Touch does appear as a drive, I learned this when I took mine to the Apple store for some problems I was having and they told me it works on macs, but not PC's. Typical.
There may be other programs similar to TouchCopy that are free if you look.
The new iPods are using flash drives inside so now the new iTunes will only recognize the iPod Touch and the old iPods use HARD DRIVES! So just remember that there are no disk mode in the new iPods!
Hope this helps!
Nicholas
Http://www.youtube.com/watch?v=PtsStUbjTJs
this helped me alot ;D
The Solution #2 is correct because Ipod nanos all have flash memories but you can still view them through the "my computer" app so it must be true then that the new ipod touch CANNOT be viewed through "my computer"... my guess would be that the softwear available to take information from broken down ipod harddrives is also being used to steal/share music with other ipods... and since that would take business away from itunes they made sure that it wouldnt keep happening...
this is what i think... this is no BS
IPod Touch doesn't show in "my computer"?
Can't see my my i pod touch in my computer
I found this solution to work. Try this first:
a) Get Windows to restart the drivers:
- disconnect your USB device and close ITunes
- connect your USB device
- if ITunes loads, close it.
b) File explorer:
Open File explorer and browse to
C:\Program Files\Common Files\Apple\Mobile Device Support\Drivers
In that folder there should be a set of files named "usbaapl64...."
right click on the one ending in "INF"
Select Install. It's very quick.
remove the USB device
c) Restart the computer.
When you login again, load ITunes before you attach your USB device.
d) If still not works, try re-install iTunes. Go into the Unstall Programs (in Control Panel) and uninstall everything that says Apple, and uninstall Bonjour. With the fresh install of iTunes, everything came back and is should work. Hope it helps.
f) If you just want to add some photos, songs and movies from computer to your devices, you can use an iTunes alternative to do the job.
http://www.ipod-transfer-copy.com/ipod-iphone-to-computer-transfer-cucusoft.html
IPod Touch doesnt show in "my computer"? I can't see my iPod Touch in "my computer", do I have to use iTunes? it is really annoying I would rather just do copy and paste.
<dt><p>Thanks, Very interesting read, and very helpful
<br />______________<br />
<a rel='nofollow' href="montreal'>http://www.eliteescortesmontreal.ca/">montreal massage parlor</a>
</p></dt>
IPod touch does not support the "disk" function found in classic iPods, and as such can only be accssed in iTunes etc...
Can't be fixed!
You have to go to itunes but if you realy want to copy and past just click manually manage music
thats the same with mine, i have the lastest software, but "My computer" dosnt recognise it, iTunes does tho. plz help
i connect it to the computer in open up itunes and nothing happens.my laptop and computer thinks its a camera.i dont know why
ipod touch does not recognized my computer
when i connect my ipod touch to my pc there is a problem with apple mobile device service
i want to delete pictures an certain music files and its alot quicker to do this by goin to my computer an deletin them, but my ipod touch doesnt let me do this (N)
HELP =]
No Computer will recognize my i-touch - although last week it was fine!
my ipod touch is stuck in black screen and when i plug it in it says usb device not recognized
when i connect my ipod touch it doesn't show on my computer and i want to save my files from my other computer so i don't have to erase it.
