Most dryers fail to heat for the following reasons, in order of commonality: 1) Most common, heating element has failed, needs replacement. 2) A fuse or thermostat inside the machine has failed, needs replacement. 3) A wire has burned in two or broken, needs repair. 4) A fuse or circuit breaker in the house or apartment main fuse box has "popped", needs replacement. Be blessed.
Remove the dimmer from the wall and examine the electrical connections. Did your wire nuts come loose? Are there any wires broken? It is STRONGLY advised you turn off the circuit breaker first!! If you would want, after cutting off the breaker, take the connections apart and redo them; just in case the wires losened.
Check the door switches and the wires connected to them. I've seen at least one door switch that had bad contacts literally fall apart due to overheating. It's possible you have one that is broken and twists over to touch a grounded metal part when you open the door (also inspect the bracket that holds the switch for the same issue). The same switch doesn't trip the breaker when the oven is not running because there is no power going through it at that case.
Something is wrong inside the monitor. I would call samsung support and get an answer from them. You could probably trade your monitor in aswell if its still under warranty.
There are literally dozens of brand options on the market. All are to specified standards. Contact any electrical supplier to obtain one for your system.
You should be able to fix the remote yourself with a screwdriver. if the plastic has broken of the circuit board has broken all you can do is replace it im afraid.
i used this site because my numeric keypad fell apart too..it came in a week and the keypad itself was less than £10!!i just now need to figure out how to replace it!
