Logo comes and turn off itself then restart and this cycling continues
Corrupted software [firmware]. A firmware update is necessary. It will be best to contact the authorized service center for Samsung, in this case. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Testimonial: "where do i get firmware ??"
SOURCE: samsung lcd tv power problem
Check the solution by billn352: $7 Fix! It Rocks!
billn352 even has the cost of the replacement capacitors correct! Thanks guy!
When my Samsung quit six months ago, the three solutions posted on FixYa were (1) Pay $300+ parts and $200+ labor to have it fixed, (2) Do #1 then rag Samsung until they repay you for the defective circuit board and (3) Get another TV and avoid getting stuck eith yet another defective circuit board. I chose to buy a 47" Phillips at Wal-Mart. I don't feel like paying big bucks every 18 months to keep the Samsung alive. I put the Samsung in the closet and took my lumps.
This month I revisited the solutions on FixYa and found the post by billn352! A $7 FIX and it Works!.
I pulled the Samsung out of the closet, laid it on a padded table, removed the plastic back (lotsa screws!), located the capacitors and removed the circuit board (more screws). The four capacitors are easy to locate. At least three of mine had black **** oozing out of the top of the cans. I ran down to the strip shopping center and got the four replacements at Radio Shack--under $7 with tax.
The capacitors are polarized (they have a positive and a negative lead) and I have a buddy who loves to solder and drink beer. So I asked him to do the hot stuff, assisted by a copy of the billn352 post to further identify the capacitors by component number and a six-pack of Miller Lite. Yes, the replacement capacitors are larger than the originals and Yes they fit nicely! So easy that a "drunk redneck" can do it!
I also checked the current prices for this model Samsung on the Internet. On one list, a new unit was offered for less than $400. Most I found were in the $500-$900 range. Give it another year and what do you think these sets will be worth! A $7 fix is worth doing: Maybe a $400 fix is not.
SOURCE: Samsung LN-T4032H LCD
Most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
SOURCE: My Samsung LCD TV will not turn on, it just clicks
A Replacement Power Supply.
Parts: £80 - £110 depending on the model.
Labour: £40 (ish) little bit more with a 90 day warranty etc.
Type your model number into www.chsinteractive.co.uk for the price on a PSU.
Good Luck.
SOURCE: Samsung LCD tv - Turns on and off by itself.
Not sure if this is the same problem, but I just moved and set up my Samsung 40" LCD and it has been going off and on by itself with the worst yesterday every 2-3 minutes. After speaking with a friend of mine who is not in the Tv business but just has good common sense, I determined it was likely a bad power strip. The bottom line is I replaced the crappy power strip (which was fully loaded with all 6 outlets in use) with the higher quality one I had in the other room. The problem is gone. I suspect the power strip was failing or real bad quality........try plugging the tv directly into the wall outlet first. hope this helped.
SOURCE: freezes turns white then turns off then back on
IF YOUR IMAGE IS ALL WHITE YOUR LOGIC BOARD IS DEFECT BUT IM SAD TO SAY DO NOT REPLACE THE LOGIC IT WILL ONLY TEMPORARLY SOLVE THE PROBLEM THE PANEL IS OVERLOADING THE LOGIC BOARD PANEL IS BAD
