Password Problem after **266344
password will not enter... no buttons appear to do anything except the hang up button.
is there a trick to entering the password?
Nothing displays during password entry, even if you get it wrong. All you can do is press the RETRY softkey and try another. Likely you're using the wrong password.
To change the ringing assignments on extensions enter programming mode by pressing Feature **266344 and password 266344 if it hasn't been changed. You have to do this from an M7310 phone. The top two buttons on each side will move you through programming. The top right button is the SHOW button and the button below it is the NEXT button. The top left button is the HEADER button and the button below it is the BACK button.
Your first category should be TERMINALS & SETS. Press the SHOW button and using the dial pad enter the extension number. The display should show the extension number or name. Press SHOW three times and the display should show LINE ___.
With options to SCAN or LIST. Pressing SCAN will show the lines assigned to the extension. Use the CHNG option to change how the line is on the phone. RING ONLY - UNASSIGNED - APPEAR ONLY - AND APPEAR & RING. Change the lines you want to ring in NORMAL DAY MODE to APPEAR & RING for this extension and press SCAN to move to the next assigned line. Use this same method for any extension you want to change the ringing on.
When you enter in the password the screen won't display any input. When the correct password is entered then the screen will change to terminals&sets. If entering 266344 at the password prompt doesn't change the screen, then try 23646 as an alternate password.
How to Change a Mailbox Password
1. To access the voice mail system press Feature. 2. Press 9 8 3. 3. When you see Log: enter ~ SETNNA (738662) and press OK
4. Pswd: CONFIG (266344) 5. Press "MBOX". 6. Press "CHNG". 7. Enter the mailbox number you wish to reset. 8. Press "Reset". 9. Press "Rls" to exit (orange button to the right of the number buttons).
Default password is "0000".
This is for an M7324. Place the programming overlay on the top 4 buttons of the phone. Press Feature **266344, Password: 266344 Terminals& Sets should be in the display. Looking at the overlay press Show, press Next until it shows the name or ext. that you want to change. Press the button under CHANGE in the display. Enter the new name (use the arrow over button to move to the next space). After you are done press Show and RLS. Update will appear in the display press the button to update the change.
On the phone, enter in config mode:
Feature **266344 Password 266344 Enter into A> Configuration Enter into 2. Line Access This should now prompt: Show Set: Enter the set you would like to change (extension usually) Enter into Line assignment Press Scan (soft key under display)
There you can change the lines to Appear Only (not ring on incoming call), Not assigned, Ring Only, or Appear and ring.
Parental Guide On (Activate V-Chip)
Selecting this option lets you activate and deactivate parental control settings.
1. Press MENU on the remote control (the Main menu appears).
2. Press the button until the Parental Control icon is highlighted.
3. Press the button until the bottom PASSWORD is highlighted.
4. Enter your password using the numbers buttons on the remote (the PARENTAL GUIDE menu appears).
5. Press the button to highlight PARENTAL GUIDE OFF, then press the button to turn it on. It must be
on for rating limits to take effect.
If you do not activate V-Chip, none of the settings for V-Chip will take effect.
If you forget your password, you can reset it. Enter 5898 as the password and then change it to a new one.
Child Lock
Selecting this option lets you lock (disable) or unlock (enable) the TV’s front panel. The remote still tunes to
any channel. When using this as a Parental Control method, remove access to any remote that is capable of
operating the television.
5. Press the button to highlight CHILD LOCK, then press the button to turn it on.
Change Password
Selecting this option lets you simply create a new password at any time. Once you enter a new password
from CHANGE PASSWORD in the PARENTAL CONTROL menu, it is the password you use until you change it
again.
5. Press the button to highlight CHANGE PASSWORD, then press the button to select it.
6. Press the button to highlight NEW PASSWORD, and use the number buttons on the remote to enter
the new password. Enter it again in the confirm field to confirm the new password.
