Question about Frigidaire FGB24S5A Gas Single Oven
Adjustment for timer tone - Frigidaire Gas Range
  • Official Brand Answer
  • 4,342 Answers
Hi RDWSR, this is AP. Thank you for your post.
Regrettably, you are not able to adjust the timer tone on your Frigidaire wall oven.
Posted on Mar 07, 2014
6ya staff
SOURCE:
How do I take off the top of my range to install new timer?
Good Afternoon Friend,
I understand that you are trying to replace the timer on your Frigidaire range, model# FGF326ASJ, and want to know how to take the top off your range. Typically, this is not a do it yourself repair and there are no step by step instructions on how to take the top off. I suggest contacting the manufacturer to see if they might be able to assist. The other option would be to call your local authorized technician. The technicians are trained on your specific range and will be able to take the top off and install the new timer. Hope this is helpful.
-Best Regards-
WP
May 19, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Cooking Time had Ended, Timer Tone stays on 3 second cannot hear it
This might come under a RECALL for this product. Consumer Protection Agency. If you are the original owner, they should have your registration. If not OO, contact Frigidaire at http://www.frigidaire.com/?medium=TSA&medium=tsa&refcd=GO20120517172252102477s_frigidaire_com&tsacr=GO29646139613&gclid=CPPH8ZDd_rwCFbQWMgod9GkAsA&gclsrc=aw.ds Please check your model number, I punched it in and it did not come up. This is the site to direct or talk to someone.
Mar 06, 2014 | Frigidaire FGB24S5A Gas Single Oven
I have a 30 inch Frigidaire self cleaning oven. The oven will no longer heat up in a normal amount of time using the bake function. Sometimes I can smell gas when using bake. It cant reach the desired...
Sorry to read about your problem, I hope this helps you out.
Bad gas control valve or oven temp control
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
What is the average price for a Frigidaire Gas Range es300?
Your average price range for a Frigidaire is between $560 and $800
Dec 07, 2010 | Frigidaire FGB24S5A Gas Single Oven
Oven stops working and display screen goes blank
Hello The control has developed faults in one or more of it's circuits. This clock/timer must be replaced to solve the problem. The Good news is that this is not one of the really expensive controls. Found this one for about 70$ at a website. Worth fixing- but beware the 'self-clean' function after repair, and this control should last a lot longer.  Please acknowledge this post if info helps- have more if needed- Thanks- Ed
Mar 20, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door locked
ah, you lucky guy. You can try a hard reset by unplugging the range for a good 1/2 hour, then plug back in. Unfortunutely this probably won't work, as these clock/timers are notorious for only lasting a few years. You have to blow $150+ and replace the clock/timer. Note: A hair dryer will help you get the face off the old one to put onto the new one.
Nov 10, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My frigidaire ES400 gas range is giving off a sooty smell and high levels of CO that fluctuate from 23ppm - 118ppm (FD CO METER). what is the possible cause and how can it be repaired?
Air intake needs adjustment. Remove bottom drawer, there is a gas valve and the burner attached to it. Loosen small screw on the burner and turn the air baffle to let more/less air in. If not sure what you're doing - call a repairman.
Also make sure not to cover any vents on the oven bottom with foil, as some usually do.
It also can be that the burner holes need cleaning
Oct 13, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven
Try resetting the timer to manual, consult your user instruction book.
Dec 11, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire FGB24S5A Gas Single Oven Logo
97 people viewed this question
Top Frigidaire Ovens Experts
Marvin
Marvin
Bruce Denton
Alan Chouinard
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
