Your pre-heat cycle seems to be stuck. It is to heat to that point and then hold the temp. Go to the maytag.com website. I have found them to be very helpful in locating and emailing info. They also have someone you can talk to. My Maytag appliances are registered with them, they can look up and follow all history of the appliance.
Hi
This means a
loose/broken wire on the oven temp sensor or the oven temp. sensor itself is
bad and should be replaced. To solve this issue test the oven temp. sensor, it
should read between 1080-1120 ohms, if the rating is more then that and the
door appears to be closing fine then it is the control board that is bad and
should be replaced. Hope this helps...please post back for further assistance.
Daniel
