Malber WD1000 Front Load Washer/Dryer Logo
P
Pamela Parsons Posted on Mar 06, 2014
Spin cycle not working on Malber washing machine, it is on a used boat we just bought and it is in Fort Lauderdale but coming to NY soon, boat broker says he cant locate a person to fix the Malber- an
We assumed it was a belt but a technician not familiar with the brand said he thought it was the brain of the machine. If this issue is not fixable where can I find a new machine?
antwan
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 6 Answers
  • Posted on Jan 22, 2019
antwan
Contributor
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Answers
6
Questions
0
Helped
4578
Points
6
If you're in NY I can fix it
Gearmeister
Level 1:
  • Contributor 29 Answers
  • Posted on Mar 07, 2014
Gearmeister
Contributor
Level 1:
Answers
29
Questions
0
Helped
11916
Points
67
In New York, call Malber Distribution Corp at 516-323-5299.
They can schedule a technician to fix your machine. They've been fixing Malbers for about 25 years.
Tell them Mike, in Wash DC, says hi.
5 Related Answers
Anonymous
  • 247 Answers
  • Posted on Jun 27, 2007
SOURCE: Dryer doesn't dry clothes, doesn't start right after Wash
If the machine is brand new, I imagine all you want to do is check you're using the machine correctly before you claim on the warranty. Trouble is, the design of this machine is so weird, and the instructions so poor that it's easy to get it wrong. So far as I can make out from this distance, you need to have all of: Spin Cancel: Out Half Load: In Cold/Cold: In Hot/Cold: Out Cold water supply: Available Drain Hose: Connected .... and as with most condensing dryers, you need to let it run to the end of its cycle - if you take stuff out without running the final 12 minute cooldown period, everything will come out feeling a bit clammy. If those control settings don't help, try a functional faultfinding approach. To dry properly, the machine needs to do four things at once: 1. Tumble the clothes: You can see whether this is happening or not. From your description, it sounds like this is working. If this isn't right, see if changing control settings works, but then for a new machine make a warranty call. 2. Blow hot air over the clothes: You should be able to hear the fan running, and if you open the door, the air which comes out should be quite warm. If this isn't right, see if changing control settings works, but then for a new machine make a warranty call. 3. Condense the moisture out of the circulating air: If this isn't happening, the clothes don't get any dryer - they just get increasingly hot. Before making a warranty claim, all you need to do with this problem is ensure that the supplies and settings are such that cold water (and only cold water) is getting to the condenser. 4. Pump out the condensate: If you've just washed successfully, this is probably going to be working fine. If not, then you'll start to see the drum slowly filling with water. If this happens, check the filter (p12 of the manual), then get the warranty claim going. Welcome follow-on questions or news on how you get on posted as a comment to this query. A.
Anonymous
  • Posted on Apr 01, 2008
SOURCE: washer is jumping extremely only when spinning
I own a Malber WD1000, which is several years old. Recently, I had it transported a couple thousand miles across country, and due to the size of the pickup truck it was in, the machine had to lay on its side for the duration of the trip. Shortly afterward, the machine began making a loud banging noise during the spin cycle. Additionally, the door gasket had a "wrinkled" appearance.
After taking various panels off of the machine, I discovered the culprit. The insides of the machine (drum, etc), are more or less suspended inside the outer housing. This is accomplished by means of a pair of shock absorbers on the bottom, and a pair of large springs on top. This allows the inner workings to shake a little bit during the spin cycles, without transferring the vibrations to your floor. In my unit, one of the upper springs had come loose from the frame. The solution involved tipping the machine on its side, with the top cover off, and pulling the end of the spring back through the mounting hole in the frame, then finding a nut and bolt to occupy the additional space in the hole, so that the spring could not slip back out. Getting the end of the suspension spring properly seated again was no small task, but it solved the problem, and now the washer works just great again.
Long story short, I'd check to see if all the springs are in the proper place.
Anonymous
  • 210 Answers
  • Posted on Jun 03, 2008
SOURCE: machine won't run through cycles automaticly
Sounds to me it might be a thermal pause, if your unit is running and then is required to heat up at a certain point and reach a certain tempurature before it advances, the heater is probably not coming on. The unit will therefore not advance.
Sgt 48
A
Anonymous
  • Posted on Jun 19, 2008
SOURCE: Drum does not spin
I had similar problem recently. It turned out the main controller right above the drain hose exit on the back was the problem. I got a new board from MALBER and replaced it myself. It is working now.
Gearmeister
  • 29 Answers
  • Posted on Mar 11, 2009
SOURCE: Need service for Malber 1000 heating element..
Hi. Mike here. I repair Malbers in the Washington D.C. area. The most likely problem is not the heating element, but the hi-temp (or "brown") thermostat. They cost about $25 and are very simple to install. A "Torx 1.5" screwdriver (asterisk tip) removes two screws, in back, holding top on. Lift off top, and (from the front) see silver-foil-wrapped heating assy. At lower right will be a small philips screw holding a thin wire "hasp" which holds the thermostat in place. Remove screw and hasp (without dropping in machine!), unplug two "quiik-connect" lugs (orange & red wires) and pull out thermostat to the right. New one slips right back in. Replace wires, hasp, phillips screw and top -and you're done! This is 90% sure to fix. The heating element is only about 5% likely.
One last thing ... when re-inserting new thermostat, you'll have to "wrestle" with it a bit, as the tip needs to slip into a tiny (hard to "find") hole. Keep trying, and eventually it'll fit ALL the way in, so the hasp can hold it. To purchase part, call Joel (at Malber): 800-600-8913
Oh yeah, one MORE last thing... That red wire may be burnt a little, or completely burnt in two. Radio Shack and Home Depot sell "crimp-on" lugs (1/4") like these (female). Trim back the wire, crimp a new lug on the end, and push it back onto lower terminal on thermostat. If wire is too short, of course, add a few inches of 16 guage "stranded" (lamp cord). The same stores also sell tubular "crimp-on" wire-connectors (little blue tubes) to join the old and new wires. May God bless.
I need to repair a Malber WD 1000 washer and dryer, I live in Fort Lauderdale, Florida. Do you know if there is a technician service in Florida?
Malber is no longer in business. There is no more dealer or distribution network listed in Italy or the US.
You might try calling a local appliance repair to see if they would attempt the repair. Just looking online I see where Fort Lauderdale Appliance, 1040 Bayview Dr, Fort Lauderdale, FL 33304 (954) 361-2363 has a five star rating. If they don't service foreign appliances, perhaps they will recommend?
1helpful
After 3 years spin cycle has become almost
1st the machine has to be completely level--also take off the top--there should be two springs at the top and there are also shocks at the bottom--make sure none hav come offf
2answers
Malber P21 works 3 times slower than normal; I am afraid it will just stop.
I have a Malber P21 the door was open and not turned on and it filled with water till it overflowed onto floor....any ideas?
Dryer won't dry
www.malberusa.com
61 Commercial Ave
Garden City, NY 11530
(516) 294-6660
first empty the waste container on the right buttom of your machine you have to empty that container every couple of washes.if not solved replace the heating element. the tel # above.
good luck
Hadi
Malber WD 1000 dryer help...
jack it should start turning after a while as soon as the dryer has warmed up.
Does it dry however?
2answers
Machine won't run through cycles automaticly
Sgt 48
1helpful
2answers
Malber WD800 - Will not fill
my malber sounds like a jet plane lifting off at various points during the cycle, when it's spinning, I am pretty sure.  Any ideas?
Whirlpool washer front loader model LHW0050PQ
This is not a Malber machine but the following fix has worked for the Malber washer. Try unplugging the machine for at least 2 minutes. Do not just turn it off as there is still current going to the machine .This should clear the computer. If this does not work, the imbalance may have overloaded the circuit board requiring replacement.
New Malber wd1000...how do you unlock the dryer..picked up at store
TURN THE MACHINE OFF NOW. If the machine still has the transit brackets fitted (which is what I think your post implies), operating it in a wash cycle is likely to lead to severe damage to the machine and could be quite dangerous too. You can find a copy of the manual here: http://www.absak.com/pdf/manuals/Malber/WDman.pdf Before you use the machine again, suggest you look at page 2, and check that everything that should have been removed actually has been. Turning to the question you actually asked, failure to go into a tumble cycle isn't really the sort of thing that would normally associate with packaging having been left in place. Skimming through the manual, there are hints (see page 14) that you're meant to do some counterintuitive things to make the dryer work on this model - like keeping the "half load" button pressed in. Making sure "Spin Cancel" is out is a bit more obvious, but just as important. A.
Top Malber Washing Machines Experts
vince
john h
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
