Your Convergence ICs have failed. It is very common on rear projections. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This: When you notice the symptons Use this simple test to verify. Go to the users menu on the tv. Look for the converge option probably under setup or video setting. Converge is short for convergence to align the red and blue colors to the green color.
If you cannot move the red either horizontal or vertical, then the STK chip has failed for red section. If you cannot move the blue either horizontal or vertical, then the STK chip has failed for the blue section.
If you can move both in each direction then the problem is something else.
Note if one STK chip fails, you replace both regardless.
It's always best to remove one leg, however there tolerance is so close you should be able to get an exact ohm reading, and I mean exact. Some are connected in parallel so if they're 6.8 ohm then you'll read 3.4. What is the number of the STK's you changed?
Yes, I would replace them again.
Thats correct you need to replace both stk's (STK392-110 will work I would get them from www.bdent.com) You will also need to put heatsink compound on the back of these to keep them from going bad prematurely. Also all resistors on that board will need to be checked to make sure non of them opened when the stk's went bad. Let me know if you need anything else!
Your message says you "replaced stk392-150", did you replace both of the stk`s or just one of them??? One is for RGB vertical the other is for RGB horizontal, you should always replace both stk`s as a set, Hitachi recommends you use a "replacement kit"
part number X480306", this kit includes both stk`s with a new & supposedly improved set of stk`s as well as all resistors that are required for proper set-up, they strongly recommend you change all of the parts in their kit. The only other thing besides IC`s & resistors that could cause your problem is:
1) bad dcu output (you need a scope to check this)
2) you`ve lost either the +15 volt line or the -15 volt line to the IC`s, "Fxxx" chemical fuse open in power supply.
