Peavey Pv 2600 Power Amplifier Logo
A
Anonymous Posted on Mar 06, 2014
Connect audio source to the amplifier input, no sound
Speaker no sound when the audio source is connect to the amplifier
Ifixstufff
Level 2:
Champion:
New Friend:
  • Peavey Expert 232 Answers
  • Posted on Sep 20, 2014
Ifixstufff
Peavey Expert
Level 2:
Champion:
New Friend:
Answers
232
Questions
0
Helped
81699
Points
292
Are you using the 1/4 in jacks or the balanced inputs.
My Mackie SR1530 is powering on but no sound.
If your Mackie SR1530 is powering on but you're not getting any sound, there could be a number of potential causes. Here are a few things you can try to troubleshoot the issue:
  1. Check your connections: Make sure that all cables are properly connected and securely plugged in. Check both the cables going into the speaker and the cables that are connected to your audio source.
  2. Check your audio source: Make sure that your audio source is turned on and properly connected. Try connecting a different audio source to the speaker to rule out issues with the source.
  3. Check the volume levels: Make sure that the volume on both your audio source and the speaker are turned up. Try turning up the volume to see if you can hear anything.
  4. Check the input settings: Make sure that the input settings on the speaker are correct. For example, if you are using an XLR cable, make sure that the input on the speaker is set to XLR.
  5. Test the speaker with a different audio source: If you have access to another audio source, try connecting it to the speaker to see if you can get any sound.
If none of these troubleshooting steps work, there may be an issue with the speaker itself. It may be a good idea to contact Mackie customer support or a qualified audio technician for further assistance.
Mixer signals is on but qsc 1450 amp not giving any sound when main output is connected but when run aux send to amp it gives sound. What might be the problem.
If you are experiencing an issue where the QSC RMX 1450 amplifier is not giving any sound when connected to the main output of your Mackie 16 OK mixer, but works when connected to the aux send, here are some possible causes and solutions:
  1. Check the main output level on the Mackie mixer. If the level is too low or muted, this can cause the amplifier to not produce any sound. Increase the main output level on the mixer and check if the amplifier produces sound.
  2. Check the cables connecting the mixer to the amplifier. If the cables are damaged or not connected properly, this can cause the amplifier to not produce any sound. Ensure that the cables are connected securely and are not damaged or broken.
  3. Check the amplifier settings. Ensure that the amplifier is set to the correct input source and that the input gain level is set correctly. You may also want to check if there are any protection modes or limiters enabled on the amplifier.
  4. Check the speaker connections. If the speakers are not connected properly or are damaged, this can cause the amplifier to not produce any sound. Ensure that the speakers are connected correctly and are not damaged.
  5. If none of the above steps work, there may be an issue with the mixer or the amplifier. You may need to contact a qualified technician to further diagnose and repair the problem.
Remember to always follow the manufacturer's instructions and safety guidelines when working with audio equipmen
I have a Kustom Bluetooth PA speaker. Models PA 40 BATBT That gets no sound? How can I diagnose this problem?
The symptoms you described suggest that there may be several possible issues with your Kustom Bluetooth PA speaker. Here are some steps to diagnose the problem:
  1. Check the battery: Ensure that the battery is fully charged or replace it with a new one if needed. If the battery is old or worn out, it may not provide enough power to the speaker, causing the crackling sound.
  2. Check the connections: Make sure that all cables and connections are properly plugged in and secured. Loose connections can cause crackling sounds or no sound at all.
  3. Check the volume: Turn up the volume on both the speaker and the device connected to it (such as a phone or tablet) to see if that resolves the issue. If the volume is too low, it may result in no sound or faint sound.
  4. Test the mic and instrument input: Try connecting a different microphone or instrument to the speaker to see if the problem is with the original mic or instrument. If the new mic or instrument works, then the issue is likely with the original device.
  5. Check the speaker components: If none of the above steps work, there may be an issue with the speaker's components. It's best to bring the speaker to a professional technician or authorized service center for repair.
Hopefully, one of these steps will help you diagnose and resolve the issue with your Kustom Bluetooth PA speaker.
2answers
What causes buzzing in speakers?
There are many causes of buzz, so it should be checked step by step :
- Bad connection on the input connector, or cord.
- Amplifier, basically have the block diagram like this:
25850676-l1qpqmriditabltrjczr2eku-5-0.jpg If in one block damage, buzz can be heard.In the amplifier.
Generally occurs in the PSU and / or power amplifiers.
Fix it to the experts,because it requires a good knowledge of electronics.
Blown speaker cone, does not cause a buzz.
Short circuit along the wires supplying the audio, it will not cause any sound in the speakers, including the sound of music.
Try also, disconnect the input connector, whether the buzz is still audible. If after the input connector is removed, the buzz disappears, the possibility of buzz came from another device before the amplifier.
3answers
What would cause a buzz in speakers?
- Amplifier, basically have the block diagram like this. View image.25850665-l1qpqmriditabltrjczr2eku-2-0.jpg
I want to purchase a behringer 15 band graphic equaliser and connect it to a numark 5000fx mixer via skytec pro600 power amp can you help.
The signal path to follow is explained below:
*Audio Source(Cd/LapTop/Ipod)output to,
*Numark 5000FX Input, Then master/main outputs go to,
*Behringer FBQ1502 Inputs, then outputs go to,
*Pro600 Power Amplifier Inputs, then power amp outputs hooked up with a speaker each side.
Hope this helps.
I dont know how to connect my gem sound trf152 speakers
Looks like it takes regular home theatre speaker wire. If this is a powered speaker (like a JBL eon g2), then all you need is a passive mixer, and connect the speakers to the mixer. If this is not a powered (amplified) speaker, then you will need an amplifier to boost the sound source and drive the speakers, so you would connect the mixer to the amplifier, then the amp outs to the speakers.
1helpful
2answers
How to in install the speakers to it
You will need either powered speakers or an amplifier for the speakers. If you have powered speakers with built in amplifiers, use balanced audio connection cables from the MAIN outs of the mixer to the speakers, Use XLR or 1/4 inch TRS cables.
If you do NOT have powered speakers you will need amplifier as well and speaker cables in addition to the audio connection cables above.
3answers
Peavey XR800F 8 channel - I can't get but very little sound to my big speakers. Help
Troubleshooting is always a "process of elimination." Have you tried hooking up your Peavey powered mixer to another set of speakers? How about connecting the speakers to another audio system? Your term "very little sound" could mean audio input problems, mixer/amp settings or failure and possibly speaker damage (internal passive crossovers). Please be more specific.
Top Peavey Music Experts
NOEL
NOEL
Ngoro
Are you a Peavey Music Expert? Answer questions, earn points and help others
