MSI K9MM-V Motherboard Logo
A
Anonymous Posted on Mar 05, 2014
Instalar panel frontal de audio - MSI K9MM-V Motherboard
1 Related Answer
Anonymous
  • Posted on Oct 11, 2009
SOURCE: ala hora de instalar me pide numero de serie del produto
ME PIDE EL NUMERO DE SERIE Y AL INGRESARLO DICE QUE ESE NO ES EL NUMERO DE SERIE QUE VIENE EN LA CAJA ES S/N:SVZG06113200N08415 Y DICE QUE ESE NO ES ENTONCES CUAL DIGANME POR FAVOR
I have a marantz sr8002 can I hook up a power amp to run my front speakers that need more power if so how?
Hello Nate, if you can connect an amplifier to the front channels of your Marantz, to reinforce the sound
For that you have to take the audio signal from the PreOut RCA connections on the back of the SR8002, L output and R output and these 2 signals are sent to the input of your booster amplifier
I send you the link of the user manual and on page 10 you can see the back panel of your Marantz and identified with the number 12, the "PreOut" exits area, there are located the exits that I mentioned
I hope you can listen with more presence to the front channels of your audio system
Greetings Franco Dosil
Hola Nate, si puedes conectar un amplificador a los canales frontales de tu Marantz, para reforzar el sonido
Para eso tienes que tomar la se?al de audio de las conexiones RCA de PreOut en la parte posterior del SR8002, salida L y salida R y estas 2 se?ales las env?as a la entrada de tu amplificador de refuerzo
Te env?o el link del manual de usuario y en la pagina 10 podr?s observar el panel posterior de tu Marantz e identificado con el numero 12, el area de salidas "PreOut", ah? est?n ubicadas las salidas que te he mencionado
Espero que puedas escuchar con mas presencia los canales frontales de tu sistema de audio
Saludos Franco Dosil
https://www.manualslib.com/products/Marantz-Sr8002-15515.html
How to connect a Kenwood audio video surround system to a Kenwood km 209 amplifier
Hello Patricia, the Kenwood KM 209, is a two-channel stereo amplifier, you can only send two signals and amplify them, for example, Left and right front or Main audio output and you will have greater presence of frontal sounds
Audio output left and right rear or Surround, you will have greater presence of the rear sounds
It has the ability to amplify only two channels only
I hope you have clarified the possibilities
I send you the user manual, so you can observe the connection possibilities
Hola Patricia, el Kenwood KM 209, es un amplificador estereo de dos canales, solo puedes mandarle dos se?ales y amplificarlas, ejemplo, Salida de audio izquierdo y derecho frontales o Main y tendras mayor presencia de los sonidos frontales
Salida de audio izquierdo y derecho traseros o Surround, tendras mayor presencia de los sonidos traseros
Tiene la capacidad de amplificar solamente dos canales solamente
Espero te haya aclarado las posibilidades
Te envio el manual de usuario, para que observes las posibilidades de conexion
https://www.manualslib.com/products/Kenwood-Km-209-3868175.html
COMO CONECYAR EL PANEL FRONTAL
Para esto necesitas desarmar la PC, hay unos cable que van del panel frontal y hay que conectarlos a el Motherboard. Vasa necesitar una lupa o espejuelos de aumentos para poder distinguir en donde va cada cable.
Compaq com ergo
No hablo espanol. He utilizado el traductor de google para esto. la impresora funcionara sin el de software. Win8 puede encontrar los controladores en linea. El escaner funcionara a traves del panel de control, si tiene uno. Para instalar los controladores controlan gestor de paneles / dispositivo. (encontrar signos de exclamacion amarillo) haga clic derecho. elegir actualizar los controladores. Para ejecutar el control del escaner del panel / dispositivos e impresoras. encontrar la impresora. haga clic derecho y elegir exploracion.
2helpful
Conectores del panel frontal
Download a manual here:
http://www.motherboards.org/files/manuals/107/m5ssmv1110.pdf
You need a PDF reader to read content.
Good luck
Tengo problemas con la Biostar N68S3+, al tratar de instalar windows algunas partes de la pantalla cambia de color y queda trabado en instalando dispositivos. No es el monitor ya probe con 2 monitores. La...
Yo dir?a de probar la micro y luego la memoria en distintas placas madres, para descartarlas. Yo me volcar?a a pensar que es cosa de la placa madre.
Tambien puede haber una posibilidad de que el problema este en la copia de windows (qu? version es?) Puedes probar con otra versi?n de windows o con un live cd con linux.
1helpful
Deseo instalarle unos puertos de usb y audio y video frontales pero no se donde conectarlos
Los puertos en donde tienes que conectar el USB y puertos de audio se da en el manual de la placa.
No funciona el panel frontal de los controles
Se trata de un problema de conectividad de hardware, necesario abrir el chasis y la comprobación de la conexión del cable a los puertos en el panel frontal.
17helpful
6answers
Como puedo arreglar el audio de mi compuntadora
mi pc es ACER ASPIRE T160, no puedo escuchar el sonido, el problema es desde el comienzo no da sonido ni al prender
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
