Hi,I got new Sansa E260 Mp3 player and I want to change language settings to English. I m not sure in which language the menu is displayed.Pls help me--KK
Go to the settings (equalizer symbol).
Than go down to the 5th menu item (language, sprache, langue, lingua, la lengua,Taal ...)
The first one should be english.
Welcome to Fixya. In order for you to changed the Language on your Sansa clip mp3 player, just follow the steps below.
1. Press the "Menu" button (located on the right part of your mp3 player)
2. Move to "Settings" and then press the center button to select it.
3. Select "Language".
4. Then select the deisred language.
You must be able to either follow the manual and go in timing to the language menuto shift over to english. Other wise if you are familiar with the language on the screen, then open menu- open language settings- set to English. Helpful? Good day
In order to change your language back to English or whichever language
you prefer. Please go to Settings (which is the icon with 4 bars & 2
bars are moving up & down)....select Settings to go to submenu,
then scroll down until you see FM xxx, then the line above FM xxx should
be your language menu. Select it and it will bring you to the list of
the language and you should be able to choose your preferred language
again. Hope this helps
As with any MP3 player there will be a menu, it is different with all, but with yours you go to the main menu and select settings, under there you will see Language and all you do is click it and scroll to english and you are done
turn on your sansa fuze then press the menu button then go to the picture of settings then go to the very bottom of the list and press the center button then go down 5 slots and at the very top it should say english and press that one or find someone that speaks the language and have him or her fix it
in the settings.....ie the one that looks like a equaliser......
go to the option above FM....in whatever language u can see ...the FM is written in english. that option is the language setting.
Ok, First scroll up until u see like and equalizer. It'll have 4 bars and 2 bars are up, and 2 are down. click the right button. then Move down 4, then click the right button. And from there your able to get the languages.
