Remove yours and take to THD or Lowe's. Could call first; make have to go to specialty lighting store if not available at the DIY stores.
SOURCE: We have a GDM-26 commerical coke machine. Only
If any of your drinks are freezing you need to adjust your temp setting. The suggested setting is 5. changing the temp setting basically tells the refrigerator to stop cooling when the temp hits a low degree, and to start cooling when it hits a high degree. This keeps your drinks not to hot, not too cold, but just right. If this doesn't work I would change the cold control altogether, it might've went bad. If you have a few minutes, locate the condensor fan (bottom) and make sure it is periodically turning on and off like it should.
SOURCE: cap tube
find out the horse power of compresor and freon type. then match that info up to a supco cap tube kit. sizing charts are on back of box.
mitch
northeast cooling
SOURCE: I need to replace the door bulb and the bulb above
The door bulb is a standard , I believe 32" t-12 newer units may be t-8, common bulb in stores. I've got an older gdm 23 and the bulb on top is a curved one , harder to find. Also these lights have ballasts that power them, they also can fail
