I bought a Gasmate Gas-powered Pizza Oven from a garage sale on the weekend It was in near new condition, everything was there and together. Nothing wrong, no panels, screws etc missing. It might as well been brand new. I used a brand new gas bottle, and there were no gas leaks or blockages. It fired up as expected with nice large flames coming out of the jets. There appeared to be no issues regarding flames, blocks, gas leaks, lack of fire heat, etc. There are two issues with it 1) It took nearly an hour to heat up to 150 degrees, despite the product description claiming "Heats up and ready to go in under 10 minutes" and the cooking tips brochure instructing "Before use: preheat the oven for at least 5 minutes, this will bring the temperature to around 200C" 2) The thing won't go above 175. Again, the cooking tips brochure for this product instructs "Before use: preheat the oven for at least 5 minutes, this will bring the temperature to around 200C" which implies it should do well over 175 degrees. There appears to be no heat leaking, except out of the chimney, which does not differ to that which is in the shop I understand I could fill the cavitys with insulationor heat bricks, however as stock standard it should be able to heat up to 200 degrees celcius in 5 minutes Greatful if someone could assist The product full description and manuals can be found at http://www.gasmate.com.au/uploads/Prods/11/PizzaOven_A5_Final%20LR.pdf
Many of the Pizza ovens require ceramic plates that line the bottom surface of each oven. These ceramic plates absorb the heat and retain the temperature. I never used our ovens with a bare lower surface, always applied the plates for even heat and distribution.
Testimonial: "We have tried this with 1, 2 and 3 of the heat plates with no change/improvement."
SOURCE: Natural Gas, convection oven won't heat.
If the gas valve is on(no continuity) then yeah that is it, keep in mind the ignitor could be weak. I didn't notice where you replaced the ignitor and you say it is working so that means the gas valve has continuity. You need 37 ohms on that ignitor or a total amp draw of at least 3.5 to open that valve.I have a video: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Testimonial: "Thank you for the info, very helpful."
SOURCE: Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
SOURCE: Amana Oven ARG7800E - Oven will only heat up to 150 degrees.
u sure the flame is lighting sounds like it isn't make sure u physically see the flame u might just be seeing the glow of the igniter if it doesn't light more than likely the igniter needs to be replaced
SOURCE: Brand new Frigidaire FGB24S5A Gas wall oven not registering corre
some units will need to be adjusted if you live in a high altitude above 3000ft.
SOURCE: oven heats to 185 degrees in a hour on preheat
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
