Bobbin thread is looping on top of fabric, even though tension is set at S
SOURCE: Singer Simple bottom thread is loose
hi there
raise pressure foot up thread making sure thread passes between thread guide this should solve problem never alter bobbin tension,
mary h
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
SOURCE: Singer Futura 350 bogus thread breaking error
I had the same problem for a LONG time. Yesterday I finally removed the top and the cover for the upper tension and found thread fragments under one of the discs. I removed it and used compressed air for dust clean out and it is working wonderfully. Good Luck
SOURCE: Singer 301a...sews on top of fabric
This is a tension adjustment problem. It's good to use two different colors of thread, like you did. From your description, the top thread (needle thread) tension needs to be tighter. As you tighten the tension of the top thread, you'll see that the top thread pulls the bobbin thread up into the fabric so it's no longer laying loose on the bottom of the fabric.
You'll need to have the pressure foot down when you tighten the tension. Tighten it a little, sew a practice seam, check to see what the stitch looks like. Tighten it a little more, sew, check, etc etc--until both top and bottom look the same--you shouldn't see much (if any) of the bobbin thread color on top of the fabric or the top thread color on the underside.
Let me know how this works for you, ok?
Robbie
SOURCE: singer 301a sewing machine does not sew for more
As for the bobbin thread not picking up it could be your hook timing is off. Do you know how to adjust this?
