Durabrand BH1304D 13" TV Logo
A
Anonymous Posted on Mar 04, 2014
I hit something on my remote now i cant get my tv off av
My tv remote has sync with the dvd and I cant make it go back to the tv???
use the remote av button to scroll to an av section that reconnects the tv
probably have av 1, av 2, av 3 etc and one is for the dvd, another for the play station connection another for the cd player etc
Video camera hookup.
there should be an av button on the tv turn the camera on to play back on the tv find the av button and hit it depending on the tv ther might be 1 or 2 av ports also depends on how the camera connects is it 3 wires red white and yellow or something else
How so u change the tv to go av
Have you hit the "TV/AV" button (sometimes marked VIDEO,) on the remote?
If no remote, there should be a button on the front or side of the TV marked the same.
How to connect xbox to jvc av-28gt1sjf
I assume that since you do not have remote you cannot choose another AV channel on your TV. If so you can use the RF input using a RF converter to AUDIO /VIDEO or if not the sky input must be shared through a VCR/DVD or multimedia/DTS amplifier
1helpful
I have a Akai tv model CT2569, and cant find how to switch to AV on tv or remote.Please can you help
Hi on the remote hit the input button till you see the av you have plugged into on the tv...
Cannot watch a dvd, I don't know how to switch to video 1, video 2 etc.
Does your TV has a remote ?
If yes check on you remote,you will see a sign that looks like a TV box, or something close to it, or you will see an AV sign on the remote.
Click on it it will show AV 1,click again you will see AV 2,depending on how many AV's your TV has.
How do you change the chanel to AV without remote, dont give the option on the tv buttons
check the website for the remote you have bought and enter the codes for newer models of your make of tv keep trying 1 of them should work but might not give you all functions like teletext
2answers
Tv works great, dvd is new , cant figure out the right hook up , dvd has 3 cables white yellow red
Red = right sound channel, white = left sound channel and yellow = video (picture) channel. if you have the connections matching these on the tv, then there should be an AV channel on the remote/tv control panel. Select this channel to view, if more than one AV channel on the tv, there will be a number next to the sockets you plugged into. Select the AV number and away you go.
If your tv doesn't have the correct sockets you can buy a converter to use the ariel socket on the tv.
Nintendo wii wont work with older model of Sanyo TV
how are you connecting the wii to the tv...through the rca jacks?  If so, you can not get to the input channels by the channel button.  On the remote there will be a button called either AV, Input, AV Video, Video, A/V, Input or something similar.  Hit this button until your tv goes to the appropriate av channel.
Input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
Top Durabrand Televison & Video Experts
matt martin
matt martin
ZJ Limited
ZJ Limited
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
