how long have you had it, parts and shop time may exceed the value of a new unit, I do not repair microwave, when they don't work properly I replace them
Hello - If the microwave does not heat, it could possibly have a faulty control panel, magnetron or an issue with the power supply. Contact a professional to move forward accurately.
If the microwave oven is 7 years old or less the most likely problem is the magnetron, or the inverter board, cost consideration should be carefully thought out.
the lock on the door could be loose so the microwave light will turn on but it wont heat u should press on the door or buy a new one emai me at [email protected]
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
