After washing one load, on the second load the spin cycle did not work. No noise to indicate there is a problem.
I would appreciate all the help I can get to get it fixed. Thanks......
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
if you run the spin cycle only will it spin the basket?
