D-Link AirPlus DI-524 Wireless Router Logo
A
Anonymous Posted on Mar 03, 2014
Schedule shutdown time - D-Link AirPlus DI-524 Wireless Router
How to Shut Down my Computer Automatically After a While?
To make your computer shutdown at a particular time, type taskschd.msc is start search and hit Enter to open the Task Scheduler. In the right panel, click on Create Basic Task. Give it name and a description if you wish and click Next. When asked When do you want the task to start, select One time.
Today I brought blu window phone 8.1 my phone shutdown by itself
Possible reasons :
1) I think you did not recharge it,
Or
2) Your battery is not properly fixed and it is moved from its place.
or
3) It is scheduled to shut down on a particular time. Check the shutdown time in your mobile options or settings.
1helpful
2answers
How do i shut down comand promptsw on my computer
Hi Good day!!if you are using windows go to command prompt. press windows logo key + r to display run dialog. type cmd and click ok. in the command prompt type the following commands and press enter: shutdown.exe -s -f -t 0
-s = shutdown
-f = force shutdown closing all programs
-t = time in millisecond
0 = now you can change this no. to schedule your shutdown.
for ubuntu open terminal and type -sudo shutdown 0 you can change the 0 if you want.
Hope my solution help you!!
Whenever I step away from my Macbook Air (running 10.5.8) and it goes to sleep, when I come back it says that it tried to shut down Firefox but could not. Then I have to go through several steps to cancel...
I would check the energy saver settings under system preferences and see if it is set to go to sleep after a period of time. Also check the schedule button under energy settings to see if there is a scheduled sleep setup. Hope this helps
2answers
I can't shutdown my laptop
Hold the power button down for about five or six seconds, it will shut down then. If it keeps doing this, you need to look at what is running in the background that is preventing you from shutting down via the menu.
Click START
click RUN
type in msconfig
take a look at what is scheduled to load at startup and then try to decide if you really need to have that application on all of the time. BE CAREFUL. If you don't recognize an entry, leave it alone until you can learn what it is.
Rich
Windows automatic shutdown
1. create a new text file by opening notepad. 2. paste the following in the text file:
echo off shutdown.exe -r -t 00
3. save the text file but change the .txt file extention to .bat. 4. under control panel, open task scheduler. 5. schedule a new task to run your new .bat file, whenevr the pc should be shut down.
good luck.
My acer extensa 5620 laptop is not shutdown auto matically
if you want to shutdown your laptop automatically go to power option from control panel and from there you can schedule the time after using how many minute or hour you would like to automatically shutdown your laptop. Try it !! Good luck.
2answers
How to schedule system shutdown in windows xp
Go to Start >> Run type CMD and click Ok
in the command window
just use the AT command:
AT 9:00 SHUTDOWN -f
the schedule service must be running while using the AT command.
But normally it word well
Wanna turn off the pc in a schedule time can i do it?
Go to Control Panel -> Scheduled Tasks
Create a new task for this : C:\WINDOWS\system32\shutdown.exe
2answers
How to disconnect 2nd xcomputer from net at a certain time?
Use a macro utility such as Macro Express. Here you can basically tell the computer to do anything you want.
Download a trial from here, it really is very useful.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
