Power light stays red
Go to http://www.google.com and type "Siemens SpeedStream Modem 4100 manual". It is available in PDF file.
1 Download or view the user's manual from the Magnavox website (see Resources). You will need the list of codes included in the manual. The website will direct you to the closest remote control manual available similar to the REM 350 Universal Remote. This manual is compatible with the REM 350 Universal Remote.
Press and hold the "Code Search" button until the red indicator light stays on. Release the "Code Search" button.
Press and release the "Mode" button for the product you wish to program (TV, VCR, DVD or satellite). The red indicator light will blink, then stay lit.
Enter the four-digit code from the code tables listed in the user's manual. You can also search for the code online at the Philips Universal Code Finder page (see Resources). You might have to try several or all codes listed in the manual until you find the correct one. After a valid code entry, the red indicator will turn off. With an invalid code, the red indicator flashes.
Press the "Channel Up" button with your device on (TV, DVD, VCR, or satellite). If the device responds, you have completed the programming. Once are certain you have found the valid code, make a note of it somewhere so you will not have to search for the code again.
