The blinking orange light on your Defy F640 freezer indicates a fault with the fast freeze function. There could be several reasons for this, including a malfunctioning temperature sensor or control board, a blocked or dirty air filter, or a problem with the refrigerant system.
To troubleshoot the issue, you can try the following:
- Check the air filter and clean or replace it if necessary.
- Make sure the freezer door is properly closed and sealed.
- Check the temperature sensor and control board for any signs of damage or malfunction.
- Verify that the refrigerant system is working correctly by checking for any leaks or issues with the compressor.
If you are unsure how to check these components or suspect a more serious issue, it may be best to contact a professional technician to diagnose and repair the problem.
