General Electric WBVH5200J Front Load Washer Logo
A
Anonymous Posted on Mar 02, 2014
No power to wasjer control panel
Breaker is fine - have power to the outlet - checked everything manual tells you to do and still no power to panel
2answers
Dishwasher - Miele g858scvi plus
Miele dishwashers, including the G858SCVI Plus model, typically do not have an internal fuse accessible for user replacement. However, there are a few fixes you can try to address the power issue:
  1. Check the power supply: Ensure that the dishwasher is securely plugged into a functioning power outlet. If possible, try plugging another appliance into the same outlet to verify that it is providing power.
  2. Reset the circuit breaker: Locate the circuit breaker in your home's electrical panel that corresponds to the dishwasher. Turn the breaker off, wait for a few minutes, and then turn it back on. This can help reset the electrical connection.
  3. Check the door latch: Make sure the dishwasher door is closing properly and that the door latch is engaged. If the door is not fully closed or the latch is not engaged, the dishwasher may not receive power.
  4. Examine the control panel: Inspect the control panel for any signs of damage or malfunction. Look for loose or disconnected wires or any visible issues. If you notice any problems, it may require professional service or replacement of the control panel.
A circuit was out,which included tv and frig, moved frig everything went back on! what happened?
If the whole house power wasn't down, then you could have a circuit breaker that is flaky or a wire connection in the breaker panel or at one of the outlet boxes along the way from the panel to your outlets. If it happened once, it will happen again. I'd cycle the power at the breaker, just on general principles to make sure the movable components within the breaker are where they are supposed to be. If it happens again, I'd start at the breaker and check every outlet box in that circuit for a loose connection, either a screw or wirenut. Breakers aren't expensive to replace if you can't find any loose connections along the way.
1helpful
Maytag Neptune front loader makes loud popping noise, shuts off, and trips circuit breaker. Plus, can't get the door unlocked to get the clothes out.
follow this steps and fix it. God bless you
Check Power
Check the outlet by plugging an appliance into the same outlet the washer was plugged into an running the appliance a hair dryer works good for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control
Circuit breaker is fine but still no power on one bedroom. PG&E said it might be a bad plug/outlet.
Turn off the circuit breaker and locate the plugs that are on that circuit. There is a good chance that the problem is between the closest working and faulty outlet. Starting with what appears to be the last working outlet on the circuit, check that all the wires are secure in all the fixtures and outlets.
If that does not fix the problem, a varmint may have chewed through a wire inside the wall. If you do not have experience with home wiring, you should get an electrician.
Control panel will not light up, the dishwasher was running and now it has stopped mid cycle and will not do anything. I just replaced the control panel (black plastic with buttons, not control...
I have a kitchenaid dishwasher model # KUDC10FXBL1 I went to start it and none of the buttons were working. I have checked the breaker and the wiring and everything seems to be in order.
I have a Kenmore (Whirlpool) Elite HE5 Steam front load dryer. Everything seems to work fine except there is absolutely no heat. I checked the breaker, and it wasn't tripped. I checked the lint filter and...
I think I know what the problem is, this actually happened on a dryer I repaired at one point. Low line voltage to me means that one or more hot leads is not feeding enough voltage to the heating elements (and the heating elements need both hot leads to run) which means the circuit breaker, although on, may be malfunctioning or weakening. You can check this by running your dryer and taking the cover off your circuit panel and checking voltage on the breaker. You should see 110V on each terminal to ground (put leads from one terminal to the grounding bar in the panel). If you see less than 110V on each lead to ground and less that 240V across the terminals it needs to be replaced. (You can get one for under $25.00 depending on brand). NOTE: THE BREAKER USUALLY POPS RIGHT OUT OF THE PANEL, BUT WHEN WORKING IN PANEL TURN MAIN BREAKER OFF TO THE HOUSE AND HAVE SOMEONE HOLD A FLASHLIGHT FOR YOU. IF YOU TOUCH THE LIVE BUSS BAR THAT BREAKER GOES INTO YOU WILL GET SEVERELY HURT. TURNING OFF MAIN BREAKER WILL DISENGAGE THE POWER FROM THE BUSS BARS; NOTE THAT MAIN WIRES ARE STILL POWERED SO BE CAREFUL.
2helpful
No power to selector panel
Sounds like the control panel may be dead. If you cannot get any lights to come on at all on the front panel, its probably a goner. You can check the voltage coming out of the control pc board via the schematic inside the dryer panel. I have this same exact problem. I replaced the control board 3 times because the panel seems fine if i plug it into an external power supply but will not work when plugged into my dryer. I have my jumpered and running off of a circuit breaker.
2answers
I have a 1994 Carri-Lite 633RKS camper with electrical problems
The clicking your hearing from the AC is probably just the 12 volt side of the circuit to run the AC, but it does indicate that the controls/thermostat is doing it's job, but doesn't sound like hydro is getting to AC as well as microwave. I can't imagine those being on the same circuit as far as breaker panel goes, but who knows what might have been done before you got it, unless bought new. Do you by any chance own a plug in circuit/receptacle tester, or anything like that to test for power? In the meantime, make sure AC is in off mode, then go to breaker panel & push breakers for microwave & AC, all the way off hard, then try to reset it & tell me what happens.
Top General Washing Machines Experts
ADMIN Andrew
ADMIN Andrew
How-2-Repair.com
How-2-Repair.com
Are you a General Washing Machine Expert? Answer questions, earn points and help others
