Vacuums Logo
C
Cyndi Colgan Posted on Mar 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I get PDF of Riccar manual showing wand parts for Starbright cannister
Missing distal part of suction wand on Riccar Starbright canister vacuum
Level 3:
  • Riccar Master 18,429 Answers
  • Posted on Mar 03, 2014
Riccar Master
Level 3:
Answers
18429
Questions
Helped
1403863
Points
62248
Go to the link below to download your manual
http://www.riccar.com/help/manuals/
5 Related Answers
Anonymous
  • 949 Answers
  • Posted on Mar 24, 2009
SOURCE: how do I open the Sharkplus canister vacuum? I have no manual.
Where the hose plugs into the canister,just above it should be a button that you push in to lift the top back. You did not put what the model # was,so its not easy to find things without the model #.
Below is the manual for model# ep3005t, but once your at the site you can get the right one.
The manual is a pdf file, most all are,so you need adobe reader to view the manual,also I am putting the link for the reader,it is free. Ifyou click on the links I post and it does not take you too the site just
copy the link and put it in your browser.Hope this helped you.
http://www.sharkvac.com/productDetails.aspx?ProdID=0xbTZnOD3Iw%3d
http://get.adobe.com/reader/
Adobe reader should work on xp and vista.
A Miller
  • 8404 Answers
  • Posted on Dec 11, 2009
SOURCE: No suction - Infinity Shark Vacuum NV31C
You might try sucking the sose out with another vacum from the wrong way. You might be able to remove the hose and push a broom handle or stiff wire through. If you have compressed air available, you could try that, outside.
Im sure you have a clog and if you remove it, you will be back in business.
Thanks for your interest in FizYa.com
beltronic205
Gerry Harvey
  • 1482 Answers
  • Posted on Apr 05, 2010
SOURCE: I need to replace the part of the wand that
Try espares .co/uk
Anonymous
  • Posted on Sep 24, 2010
SOURCE: Hi i have a dyson
959bd34.jpg This is the entire assembly that you would need to replace. According to the technician that serviced mine, DC18 is prone to fail in this area due to owner's use or abuse in my case (LOL). He said forcing the handle to stand upright after you finished vacuuming puts a stress on the plastic hook that rotates the valve from floor mode to wand mode. The trick there is when you replace the handle to upright, you have to step down on the wheel to the floor. It cost me $70 to have it replace. Since I still have it on warranty, only the labor is no charge. The damage on my machine I admitted is not workmanship or material defect but improper use of the machine. I hope this helps. Just beware of some Dyson Authorized Service Center that wheel and deal you for something like, the carpet fresh powder caused your machine to clogged and blah blah. You will know if the problem they tell you is not even close to the ones I discussed.
askdyson
AskDyson
  • 2572 Answers
  • Posted on Jun 28, 2011
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: Dyson stowaway hose seems clogged..
    Sorry to hear you're having a problem with your Dyson. You should find the issue easy to resolve - please visit the Support section of our website and follow these simple steps to make sure everything is correct with your machine:
    http://www.dyson.com/support/help.asp?article=1009&product=DC21-MOTORHEAD_US
    It's also a good idea to wash your filters, which should be done every 3-6 months. You can see a video guide demonstrating how to do this here:
    http://www.dyson.com/support/help.asp?article=1011&product=DC21-MOTORHEAD_US
    If you've tried these steps and are still having difficulties, please get in touch with us free, on 08002980298 (UK), or 1866MYDYSON (US), so we can run through some checks over the phone.
    Kind regards,
    Jack
    Dyson Customer Service
    RICCAR 220 CANISTER VACCUM CLEANER POWER HEAD FALLS OFF OF WAND.
    There is a little tab that releases when you push the pedal. The tab is probably worn and needs to be replaced. This repair is not hard to do when you know how but can be difficult if you've never done it. You can get the parts and advise from your local Riccar dealer
    I need a manual for Royal 4600 cannister vacuum
    I have a PDF from Royal for you.I would be happy to email it unless it is possible to post it here..?
    What size replacement belt for riccar 1700 vacuum
    You need to contact your local Riccar dealer. They are not available except from Riccar dealers.
    www.riccar.com
    Sorry.
    Is there a reset button
    The reset button is internal. If it overheats it will shut off but will come back on when it cools down. This usually means you have a clog somewhere or a clogged bag or filter. If that doesn't take care of it have it checked by your Riccar dealer.
    My rather old cannister vac has something clogging the hose. Any ideas on how to clean it out ?
    Attach hose to exhaust port of canister. Switch on. That may be enough to blow out the clog. If not, place wand end of hose to intake of vacuum so you have both ends "attached to the vacuum. This should do it. If not, you might try using something with greater suction. Like taking it a nearby carwash and using a vacuum there. Try placing "wand end" of hose to other hose first and turn in. Then the other end.
    You can try pushing a long length of PVC or similar pipe through. No jamming. Care needs to be taken when doing this as it may cram the clog tighter,
    If the hose is rather old as well, it may be a good idea to simply replace it. It likely has multiple leaks and great loss of suction.
    No suction
    If the motor is running and is not full of dirt, and the hose is not plugged, the canister must be cracked or open somehow.
    3helpful
    Vacuum not picking up
    At the top of your wand, do you have a plastic swivel that cover a hole in the wand? This is for when you are cleaning curtains, and if that is open, or cracked you will loose suction there... also check your hose for cracks, or breaks. If it were in the shop I would put a gauge on it... normal suction is about 80-95 inches of water lift at the end of the hose. Once you have check each section of the hose, and wand, check the housing for cracks, a missing gasket (Very Good Reason For Lack Of Suction) As to your Filter, how long have you used that one filter, you can clean them for a while, but once a paper filter gets full of FINE dust you won't get it all out, you will have to replace the filter itself at that point. I hope this was helpful.
    6helpful
    2answers
    My DC05 Dyson suction has stopped...there are no blockages, the seals are good, there seems to be more suction coming from a yellow box which is situated at the top of the removable cannister. There is...
    My Dyson had exactly the same problem. I found the problem was caused by a blockage in the hose. Take the hose out where it joins the cleaner (it will come out if you pull it downwards gently) and take the hose out of the handle by squeezing the yellow buttons on either side. I pushed a rubber alkathene pipe down and found a piece of plastic was blocking it even though at first I was sure it wasn't blocked.
    Top Riccar Vacuums Experts
    ADMIN Andrew
    ADMIN Andrew
     Mikey
    Mikey
    Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
