Loose toilet seat. Can't get at anything to tighten!
SOURCE: How to tighten the hinges on a slow close toilet seat?
You don't want to overtighten since you could crack the porcelain. Are your rubber washers in good shape? This will help. You should be able to do this w/out doing any damage.
SOURCE: We have 3 soft closing Toilet seats.Newly
Reach under the bowl of the toilet and feel for a rather large wing-nut bolt on each side of the toilet. You must hold these with your hand and tighten the screws with a screwdriver. If you don't hold these wingnuts, then the screws will keep spinning forever and never tighten. Run your hand directly below the toilet just below the screws and you will find them. VERY EASY FIX!
SOURCE: loose Toto toilet seat
Lift up plastic caps located on ends of hindge behind seat. use flat screw driver and hold the nut under the outside toilet rim with your fingers or a pair of pliers. Do not over tighten or might crack the bowl.
SOURCE: loose toilet seat
If the screws don't tighten the either the screw threads are stripped or the attachment nut is stripped. Take the screw and nut to any hmoe repair center and get new ones. remember don't over-tighten then screws as this will crack the unit.
SOURCE: My toilet seat is loose but there are no visible
where the hinges sit, use a small screwdriver and prise off the top chrome cover.Under neath are the securing screws for the seat. tighten these carefully until seat is secure, then replace the covers.
