Water is going in and been pumped out but its not washing just making noise so it looks like that the waters is not being pumped round during the wash
SOURCE: Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
SOURCE: The dishwasher does not drain water
My dishwasher's problem was that something got stuck in the drain at the bottom of the dishwasher pan. I took that apart cleaned it and it worked. Apparently this problem is inherent to this model and will probably be recurring. Be prepared!
SOURCE: Does not pump water during the wash cycle.
It sounds like you are on the right track.
Open the dishwasher, remove the bottom rack, then remove the thumb nut in the middle of the unit that secures the lower wash arm and housing. Look for debris and clear any you find. Try again. If no joy, you will have to repeat the first step and also remove the wash pump upper housing that is secured with torx head screws. Same thing after you remove it - look for debris in the impeller area and remove it.
If you have to remove the wash impeller, you will need a 1" offset box wrench and as I recall a 1/4" socket. The 1" offset box wrench is needed to keep the impeller from turning while you remove the center nut. You will also need to remove the upper discharge line retainer clip to get that out of your way. Inspect the impeller for any debris and especially cracks or missing blades. If the impeller is damaged it will need to be replaced.
While you have this thing apart, check the lower wash arm and upper wash arm discharge pipe assembling for any obstructions.
I am assuming the motor runs ok and the timing cycles seem normal.
SOURCE: No water running through cycle once filled....making humming noise once clicks into cycle
Both problems sound like motor has failed or is failing.
SOURCE: Motor just hums during the wash cycle. Put it in
OK, that piece of glass may have jammed the wash impeller. this will destroy the motor windings. you will need to gain access to the circulation motor asap.the impeller is attached to the motor that is housed within the pump casing(upper). try to manually move the impeller. if its stuck, try ot remove the obstruction.
It is possible that, the motor is already damaged to the point of no return. in this case, replace the circulation motor. your drain pump should be ran by a totally separate motor(wax).
**NOTE
Some models have two impellers inside the pump - one, wash impeller,
takes care of the wash cycles, the other, drain impeller, drains the
water out. If the drain impeller is broken (broken blades, shaft), the
dishwasher would not drain. Replace any broken pump components.
